How to test VPN from Phone in Packet Tracer
Alan Charli
Hello Cisco community,
I was wondering how can I use VPN from phone?
I did the configuration but I don't know how to test or whether the configuration is correct or not,
find the attached Zip file
please help
Thanks in advance
if you open the VPN Phone, under the 'Desktop' tab, there is a 'VPN' button which allows you to test the VPN functionality...is that what you are looking for ?
Yes, that what I'm trying to test,
What should I type in each section?
Because there are many fields to fill,
Confused with what I configured in the router
