How to use multiple virtual web servers with one 1 public IP address?
Daariimaa
I'm working on a solution where we will be setting up 40 virtual web servers on a single server using Linux Redhat and VMWare .
Unfortunately, we only have 3 free public IP addresses to use, so I  need to have a basically a single public IP which would route a request  to the appropriate server. All web server using TCP 80 port.
which kind of solution in cisco router and switch ?
Tnks
Bayasaa.B
kelvinboar
PAT (Port Address translation) will be the answer, you'll need to set this up on you router or edge firewall.
