HSRP 3750-X Routing
tedtucker
My DC gives me two networks, a routing network /29 and a user network /28
x.x.x.1 – HSRP Gateway
x.x.x.2 – Edge Router 1
x.x.x.3 – Edge Router 2
x.x.x.4 – User
x.x.x.5 – User
x.x.x.6 – User
/28
x.x.x.100 – User
x.x.x.101 – User
x.x.x.102 – User
x.x.x.103 – User
x.x.x.105 – User
x.x.x.106 – User
x.x.x.107 – User
x.x.x.108 – User
x.x.x.109 – User
x.x.x.110 – User
x.x.x.111 – User
x.x.x.112 – User
x.x.x.113 – User
x.x.x.114 – User
Using a Cisco 3750-X (IP Base) what would be the best way to route between these? InterVlan routing? The /28 additional network is routed to "x.x.x.4 – User "
Leo Laohoo
The new 12.2(55)SE IOS (IP Base feature set) supports RIPv1, RIPv2, IS-IS plus OSPFv1.
Reza Sharifi
Since this a small network with 3 devices and you only have IP Base IOS on the switch, static route or RIP ver2 works fine.
Reza
tedtucker
So I create a Vlan for the Interface that connects to the DC and assign it a IP of x.x.x.4 then create a vlan for all of my servers and a static route to my DC gateway of x.x.x.1?
