12-11-2013 04:23 PM - edited 03-04-2019 09:50 PM
Hi all,
We have two routers, running HSRP between them.
Our ISP have reported that their PE router (192.168.10.81) is getting hammered with attempts from 192.168.10.84 (our secondary router) trying to establish BGP with it.
HSRP seems to be configured correctly however am unsure if BGP is configured correctly to use the HSRP IP for the BGP relationship.
Can someone please assist with diagnosing the problem, that is why does our secondary router continue to attempt a BGP relationship with ISP PE router?
Config & status outputs are below:
Many thanks in advance.
Rama
Primary router MELRTRW001:
interface GigabitEthernet0/1
bandwidth 76800
ip address 192.168.10.83 255.255.255.248
no ip proxy-arp
ip nbar protocol-discovery
max-reserved-bandwidth 100
service-policy output 75Mbs_WAN_Service
ip route-cache flow
load-interval 30
standby 2 ip 192.168.10.82
standby 2 priority 110
standby 2 preempt
standby 2 authentication cpaaust
standby 2 track GigabitEthernet0/0 50
Secondary MELRTRW002:
bandwidth 76800
ip address 192.168.10.84 255.255.255.248
no ip proxy-arp
standby 2 priority 90
BGP Neighbour status from primary router:
melrtrw001#sh ip bg neighbors 192.168.10.81
BGP neighbor is 192.168.10.81, remote AS XXXX, external link
BGP version 4, remote router ID 192.168.10.81
BGP state = Established, up for 4w4d
Last read 00:00:00, hold time is 90, keepalive interval is 30 seconds
Neighbor capabilities:
Route refresh: advertised and received(old & new)
Address family BGP IPv4: advertised and received
Message statistics:
InQ depth is 0
OutQ depth is 0
Sent Rcvd
Opens: 3 2
Notifications: 0 0
Updates: 2 93
Keepalives: 94525 96565
Route Refresh: 0 0
Total: 94566 96660
Default minimum time between advertisement runs is 30 seconds
For address family: BGP IPv4
BGP table version 724, neighbor version 724/0
Output queue size : 0
Index 1, Offset 0, Mask 0x2
1 update-group member
Inbound soft reconfiguration allowed
Default information originate, default sent
Inbound path policy configured
Outbound path policy configured
Route map for incoming advertisements is IMPORT-POLICY
Route map for outgoing advertisements is Routes_to_ASXXXX
Sent Rcvd
Prefix activity: ---- ----
Prefixes Current: 34 64 (Consumes 3024 bytes)
Prefixes Total: 48 165
Implicit Withdraw: 0 18
Explicit Withdraw: 14 83
Used as bestpath: n/a 55
Used as multipath: n/a 0
Outbound Inbound
Local Policy Denied Prefixes: -------- -------
route-map: 166 0
Bestpath from this peer: 9 n/a
Total: 175 0
Number of NLRIs in the update sent: max 0, min 0
Connections established 2; dropped 1
Last reset 4w4d, due to Peer closed the session
Connection state is ESTAB, I/O status: 1, unread input bytes: 0
Connection is ECN Disabled
Local host: 192.168.10.82, Local port: 179
Foreign host: 192.168.10.81, Foreign port: 53013
Enqueued packets for retransmit: 0, input: 0 mis-ordered: 0 (0 bytes)
Event Timers (current time is 0xA90582B4):
Timer Starts Wakeups Next
Retrans 94530 0 0x0
TimeWait 0 0 0x0
AckHold 96607 93701 0x0
SendWnd 0 0 0x0
KeepAlive 0 0 0x0
GiveUp 0 0 0x0
PmtuAger 0 0 0x0
DeadWait 0 0 0x0
iss: 938153014 snduna: 939950022 sndnxt: 939950022 sndwnd: 16384
irs: 3031418952 rcvnxt: 3033258450 rcvwnd: 16175 delrcvwnd: 209
SRTT: 300 ms, RTTO: 303 ms, RTV: 3 ms, KRTT: 0 ms
minRTT: 0 ms, maxRTT: 300 ms, ACK hold: 200 ms
Flags: passive open, nagle, gen tcbs
IP Precedence value : 6
Datagrams (max data segment is 1460 bytes):
Rcvd: 190810 (out of order: 0), with data: 96607, total data bytes: 1839497
Sent: 189490 (retransmit: 0, fastretransmit: 0, partialack: 0, Second Congestion: 0), with data: 94531, total data bytes: 1797007
BGP Neighbour status from secondary router:
melrtrw002#sh ip bgp neighbors 192.168.10.81
BGP version 4, remote router ID 0.0.0.0
BGP state = Active
Last read 00:00:13, hold time is 180, keepalive interval is 60 seconds
Message statistics:
InQ depth is 0
OutQ depth is 0
Sent Rcvd
Opens: 64393 0
Notifications: 0 0
Updates: 0 0
Keepalives: 0 0
Route Refresh: 0 0
Total: 64393 0
BGP table version 605, neighbor version 0/0
Default information originate, default not sent
Sent Rcvd
Prefixes Current: 0 0
Prefixes Total: 0 0
Implicit Withdraw: 0 0
Explicit Withdraw: 0 0
Used as bestpath: n/a 0
Outbound Inbound
Total: 0 0
Connections established 0; dropped 0
Last reset never
No active TCP connection
Debug IP BGP logs on secondary router below:
Dec 11 23:53:19: BGP: Applying map to find origin for xxx.xxx.xxx.xxx/30
Dec 11 23:53:23: BGP: 192.168.10.81 went from Idle to Active
Dec 11 23:53:23: BGP: 192.168.10.81 open active, delay 21059ms
Dec 11 23:53:44: BGP: 192.168.10.81 open active, local address 192.168.10.84
Dec 11 23:53:44: BGP: 192.168.10.81 went from Active to OpenSent
Dec 11 23:53:44: BGP: 192.168.10.81 sending OPEN, version 4, my as: XXXXX, holdtime 180 seconds
Dec 11 23:53:44: BGP: 192.168.10.81 send message type 1, length (incl. header) 45
Dec 11 23:53:45: BGP: 192.168.10.81 remote close, state CLOSEWAIT
Dec 11 23:53:45: BGP: 192.168.10.81 -reset the session
Dec 11 23:53:46: BGPNSF state: 192.168.10.81 went from nsf_not_active to nsf_not_active
Dec 11 23:53:46: BGP: 192.168.10.81 went from OpenSent to Idle
Dec 11 23:53:46: BGP: 192.168.10.81 closing
Dec 11 23:54:06: BGP: 192.168.10.81 went from Idle to Active
Dec 11 23:54:06: BGP: 192.168.10.81 open active, delay 24058ms
HSRP status on primary router:
melrtrw001# sh standby GigabitEthernet0/1
GigabitEthernet0/1 - Group 2
State is Active
4 state changes, last state change 4w4d
Virtual IP address is 192.168.10.82
Active virtual MAC address is 0000.0c07.ac02
Local virtual MAC address is 0000.0c07.ac02 (v1 default)
Hello time 3 sec, hold time 10 sec
Next hello sent in 1.852 secs
Authentication text "cpaaust"
Preemption enabled
Active router is local
Standby router is 192.168.10.84, priority 90 (expires in 8.132 sec)
Priority 110 (configured 110)
Track interface GigabitEthernet0/0 state Up decrement 50
IP redundancy name is "hsrp-Gi0/1-2" (default)
melrtrw001#
HSRP status on secondary router:
melrtrw002# sh standby GigabitEthernet0/1
State is Standby
Next hello sent in 0.808 secs
Preemption disabled
Active router is 192.168.10.83, priority 110 (expires in 8.528 sec)
Standby router is local
Priority 90 (configured 90)
Solved! Go to Solution.
12-11-2013 09:30 PM
Hello Ramazan,
Based on the configuration shown so far we can see that HSRP is doing it's job but the problem is with the BGP relationship as the Secondary unit is trying to bring up a TCP session from the Virtual HSRP address which is already up.
This is the expected behavior as with HSRP you can always source traffic from an interface and not for a specific interface.
That being said can you configure the following on the HSRP routers and let us know if it helps
neig x.x.x.x transport connection-mode passive
Rate all of the helpful posts!!!
Jcarvaja
Follow me on http://laguiadelnetworking.com
12-11-2013 09:30 PM
Hello Ramazan,
Jcarvaja
12-12-2013 12:29 AM
The solution by Julio is great routers will passive wait for bgp session to establish from the ISP to your active router.
cheers
12-12-2013 04:49 AM
Thanks for the comments
This should fix the problem.
Jcarvaja
12-12-2013 03:25 PM
Hi Julio,
Thanks for the reply. It's very much appreciated.
This sounds like a great way to fix it, though I'm sure Milan's suggestion would also work.
I'm really looking for the least disruptive method with minimal changes at this point. Organisation & carrier embargo's will be in place soon too.
I can apply the following command to my secondary router.
Will i then need to apply the equivalent 'active' command to my primary router? I would think not as our ISP only has a BGP relationship configured with our primary router IP & is working fine.
Thanks again
Rama
12-12-2013 03:55 PM
Rama
Your BGP peering with the ISP is only working because it is passive ie. from your output -
this shows that the ISP router started the connection to your primary router. Using HSRP as the neighbor address only works when the neighbor initiates the connection. When your router tries to start a connection it uses it's real IP not the virtual one and so the neighborship cannot be formed. That is one of the drawbacks to using the HSRP virtual address.
So there is no point in using active, in fact if you did you would never get a peering on the primary router. You need to apply the command Julio supplied on both routers because if HSRP has to failover then your current primary router would then be sending requests to the ISP router and you would have the same problem you have now.
Actually i think, although i cannot test it, it could be worse than this. Your current primary (R1) fails. Your standby router (R2) takes control of the virtual IP/virtual mac address. Your standby router has no BGP session and cannot initiate one because you are using the HSRP virtual IP. So you have to wait for the ISP router (SP1) to realise the connection is dead and tear it down. But what happens if R1 failed and rebooted itself. While it was rebooting SP1s holdtime expired, it tears down the connection and tries to open a new one. A new connection is established with R2. R1 finishes rebooting, comes back online and takes back control of the virtual IP/virtual mac. The keepalives sent by SP1 are to the virtual IP so they go to R1. But R1 has no BGP session open. R2 does not get any keepalives so it thinks the connection is down. In addition because R2 no longer controls the virtual IP i am not sure whether it could send any keepalives with that as the source IP. Either way the connection is broken and you have to wait again until SP1 times that connection out and switches back to R1.
I cannot say for sure the above would happen, and would be interested to hear other's opinions on this, but i can't see why it wouldn't.
As i say, to answer your specific question the same command needs to be applied on both routers. I do not know whether you can apply that command on your primary router without it resetting the peering because i have never done it before. It may be, because the connection is passive anyway, that it will not reset the connection but i can't say for sure.
Perhaps Julio can answer.
Jon
12-12-2013 05:08 PM
Hello All,
No, the session will not be torn down but of course changes will not be present till you clear the BGP relationship.
Jcarvaja
12-13-2013 01:59 AM
Julio
Why is the session not torn down when the HSRP virtual IP changes to the backup router ?
Can you explain how it would work from the example i described. If R1 fails, R2 takes control of the virtual IP. Keepalives are still being sent by SP1 to the virtual IP but these go to R2 now. R2 has no BGP session open and cannot initiate one, it can only wait for SP1 to start the connection.
So i would have thought that SP1 would have to tear down the session to R1 because it was not getting any keepalives and start a new session with R2.
I'm not saying i am right, just want to understand how the BGP session is switched to R2 without tearing down the old one and starting a new one.
Jon
12-13-2013 02:22 AM
Hi Jon,
this is exactly what I also think.
I made a quick test yesterday in my lab to prove and the BGP session was restarted when HSRP swapped!
There might be also another issue - a different BGP router ID (unless configured the same on both routers)!
@Julio:
Are you using some trick to keep the BGP session up?
Best regards,
Milan
12-13-2013 02:39 AM
Hi Milan
In your lab setup when HSRP swapped how long did it take for the new BGP session to start ? Did you have to wait for the holdtime to expire before it tried to open up a new connection to the HSRP virtual IP ?
I don't have anything to test with but i am assuming that when R2 starts receiving keepalives from SP1 it simply ignores them because it does not have a TCP session already open.
Jon
12-13-2013 05:29 AM
Hello Jonm
I tought that we were talking about when we use the passive command, not when we changed the BGP neigbhor IP address.
To what you are referring the answer is yes, should be restarted.
Jcarvaja
12-13-2013 05:43 AM
Julio
Thanks, that makes more sense now
Jon
12-17-2013 04:03 PM
Thanks guys
So to confirm, i have currently only made added the passive command to my secondary router which has stopped the ISP from complaining.
However reading the posts, i should be adding the same command to the primary router.
1. Will this cause an issue with the present bgp relationship?
2. Will i need to do a soft clear for it to take effect? and will this cause the bgp relationship to restart?
Rama
12-17-2013 11:55 PM
Hi Rama,
IMHO,
a) You would need your ISP to configure
nei ... transport connection-mode active
on his router to be 100% sure this solution works fast under any conditions.
b) I still think this is not an optimal design.
As your BGP session will get restarted any time your HSRP flaps for any reason.
Why don't you configure a standard primary/backup solution with both your routers peering to the ISP router(s)?
Best regards,
Milan
12-18-2013 03:01 AM
Rama
1) According to Julio, not it won't.
2) You don't need it to take effect because your connection from the active router is already passive so just leave it.
That said, i agree with Milan. It is not an optimal design in terms of redundancy. In addition to HSRP flaps if you needed to take the primary down for maintenance it would switch to the backup. But as soon as you brought the primary back up you would lose BGP again until it switched over.
With 2 separate peerings this would not be an issue.
Jon
