HSRP Configuration
Amit John
I am trying to configure the below HSRP. Router and switches configured as below
R1 config
interface FastEthernet0/0
ip address 10.0.0.1 255.255.255.0
standby 10 ip 10.0.0.10
standby 10 priority 110
standby 10 preempt
standby 10 track 1 decrement 30
duplex full
interface FastEthernet1/1
ip address 20.0.0.1 255.255.255.0
standby 20 ip 20.0.0.20
standby 20 priority 110
standby 20 preempt
standby 20 track 2 decrement 30
speed auto
duplex auto
R2 Config
ip address 10.0.0.2 255.255.255.0
standby 10 priority 90
standby 10 preempt
duplex full
ip address 20.0.0.2 255.255.255.0
standby 20 preempt
speed auto
duplex auto
the result as you can see below
the high drop becuase I forget add preempt in R2 two interface
after I add it and check only one ping drop I see
MHM
9 Replies 9
Config hsrp in each site
Make sure the hsrp active is same for both sides but modify priority
Config track in hsrp to change priority in which if one hsrp side active status change the other side also change.
MHM
Amit John
I had done every configuration except configuration track in hsrp. Please go through the images i sent. Tried it many times. The issue is i am able to ping 20.1.1.254. But when I shut the active one the standby is not working. But when I again use no shut , the main router is back. So that I think preempt is working. But dont know standby is not working
Show ip
interface breif
Check the IP and if the interface is up/up
In SW all port in same vlan?
MHM
This is a complete list what you have asked for, everything is fine, as I told before same issue. Preempt is working, but standby is not working. could you find a solution?
1st go through
CE1 ip brief. then,
CE2 ip brief. then,
CE1 standby brief
CE2 standby brief
ping status
after shut CE1.
Amit John
1st o through the architecture. Same architecture, In this you can see a red cable which I used for shuting, nothing to worry about it.
I will run lab and share with you all config
MHM
Amit John
Thank you for your efforts.
Tags means i didn't get you.
R1 config
standby 10 preempt
duplex full
standby 20 preempt
speed auto
duplex auto
R2 Config
standby 10 preempt
duplex full
standby 20 preempt
speed auto
duplex auto
MHM
