HSRP Isolation on ASR with OTV
cbreger15
I am setting up a pair of ASR 1004s with OTV over dark fiber.  OTV is working fine, and I was going to add the ACLs for HSRP isolation.  Before I did I wanted to see if HSRP would work across the OTV link and then add the ACL to confirm it is blocking.  I can't get the the SVIs acorss the OTV link to sync via HSRP.  I read on a few blogs that HSRP isolation is inherit now in new versions of code when running OTV.  I can't seem to find anything offical.  Can any confime this is the case?  We are runnning IOS-XE 03.13.03.S.
Thanks is advance.
Hello.
The filter is on by default for L3 only (since IOS XE 3.5). You may disable it by "no otv filter-fhrp" command. More details - http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/wan/command/wan-cr-book/wan-m1.html#wp3953249580
At the same time if you want to isolate your FHRP between datacenters you must configure L2 ACL (to drop FHRP MACs) and apply it inbound on LAN-facing service instances.
