http connection failures after installing C2960G switches
Owen Mould
I have seen this at two sites now: after migrating the site T1 to 10-Mbps Opt-E-MAN and replacing old 10/100 switches with 10/100/1000 switches, users frequently get http connection errors. The error goes away if the user reloads the page--sometimes they have to reload more than once. They never had this problem before.
I thought it was due to the large number of 5-port desktop switches infesting the networks (I'm getting rid of them as fast as I can) but it happens even on a PC directly connected to one of the new GigE switches. It does not happen when accessing internal web pages.
It looks like a DNS failure -- but nothing has changed in our DNS setup, except that users have a fatter pipe to our DNS servers.
Any ideas? How do I explain to users that giving them a faster network breaks their web browsing?
Reza Sharifi
What is the output of "sh ip int gix/x/x"?
gix/x/x is the 10-Mbps interface that connects to the provider
Also, is the connection to the provider fiber or copper?
GigabitEthernet0/0 is up, line protocol is up
  Internet address is 10.100.1.5/24
  Broadcast address is 255.255.255.255
  Address determined by non-volatile memory
  MTU is 1500 bytes
  Helper address is 10.3.0.51
  Directed broadcast forwarding is disabled
  Multicast reserved groups joined: 224.0.0.10
  Outgoing access list is not set
  Inbound  access list is not set
  Proxy ARP is enabled
  Local Proxy ARP is disabled
  Security level is default
  Split horizon is enabled
  ICMP redirects are always sent
  ICMP unreachables are always sent
  ICMP mask replies are never sent
  IP fast switching is enabled
  IP fast switching on the same interface is disabled
  IP Flow switching is disabled
  IP CEF switching is enabled
  IP CEF switching turbo vector
  IP multicast fast switching is enabled
  IP multicast distributed fast switching is disabled
  IP route-cache flags are Fast, CEF
  Router Discovery is disabled
  IP output packet accounting is disabled
  IP access violation accounting is disabled
  TCP/IP header compression is disabled
  RTP/IP header compression is disabled
  Policy routing is disabled
  Network address translation is disabled
  BGP Policy Mapping is disabled
  Input features: Ingress-NetFlow, MCI Check
  Output features: CCE Post NAT Classification, QoS Marking, Post-Ingress-NetFlow, Egress-Netflow
  WCCP Redirect outbound is disabled
  WCCP Redirect inbound is disabled
  WCCP Redirect exclude is disabled
The connection to the provider is copper to a Cisco ME3400; from there on it's fiber.
Owen Mould
Found the problem : I'm an idiot. I set the default route as GigE0 -- the int itself. It worked, but the arp table was enormous! I reconfigured it to use EIGRP and all was well. Embarrassing, but I'll leave it up for the edification of others.
Sent from Cisco Technical Support Android App
