Hub to spoke Sites: Site to multisite connection on 1841 Cisco router
Jigar Dave
Level 3
Level 3
I need some idea how I can go about this.
giving some more info.
# already on Ho 1841 router client VPN set up is running. but I need to run site-to-site VPN on same 1841 router #
at HO we have 1841 router, we have 10 field offices, these field offices will be having internet public IP and connecting to HO via internet
I want to configure site to site VPN connection to pull traffic from field offices to HO in secure tunnel.
I have public IP on HO router and all field offices are having public IP.
I have following idea
1. at every field office, I need to create crypto map, IKE parameters, interesting traffic towards HO
2. in HO router - I need to create crypto map, IKE parameter
but here I am stopping, I dont know what configuration needs to be in HO(hub) router to connect to every field office - should I need to configure different crypto-map on HO router? all field office have different public IP so how I can accomodate them in HO?
Thanks in advance
Jigar
Hi Jigar,
One crypto map at the HO should be enough.Please find below a sample config that you need to put on your HO
crypto isakmp policy 10
encr aes
authentication pre-share
group 2
crypto isakmp key abcd1234 address 203.1.1.2
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto map CRYPTO_MAP_1 10 ipsec-isakmp
set peer 203.1.1.2
set transform-set ESP-AES-128-SHA
match address 100
crypto map CRYPTO_MAP_1 20 ipsec-isakmp
set peer 202.14.1.5
match address 100
interface fa0/1
Kishore
PLease rate if helpful
