Hundreds of Static Routes for an IP
ALIAOF_
Level 6
Level 6
We have a Cisco 7301 concentrator, well two of them in HSRP configuration.  We have multiple VPN's setup on that router (crypto map based).  Recently we noticed the following:
- There is one IP address that has hundreds of static routes for some reason
- VPN for this customer is working, but I'm trying to find out why this is happening.
Here is how it looks like:
S 0.0.0.0 0xF5FFFF2C [1/0] via "ip-address"
There are hundreds of entries for a single IP there.
Richard Burts
I suspect that this is related to how you have set up VPNs on the router. Perhaps you can post the config?
Rick
Rick
We have like 50 more setup just like this one but this is the only one doing it.  Pretty simple setup.
There is a ISAKMP policy, Transform Setup, Crypto map, ACL for the Crypto map and then couple of NAT statements NATing the remote IP's.
