HWIC-3G-HSPA or HWIC-3G-HSPA-G ?
mladentsvetkov
Dear All,
Would you please help me to choose between HWIC-3G-HSPA and HWIC-3G-HSPA-G?
From the data sheet (http://www.cisco.com/en/US/prod/collateral/modules/ps5949/ps7272/product_data_sheet0900aecd80600f41.html) I can see that the only difference is the IOS image supported and the Sierra modem version:
"Software compatibility ...
... Modular Cisco 1900,2900,and 3900 series Integrated Services Routers supported with Cisco IOS Software release :
• Cisco IOS Software feature set: Universal IOS image
HWIC-3G-HSPA supported with 15.0(1)M1 or later
• HWIC-3G-HSPA-A** supported with 15.1(1)T or later
HWIC-3G-HSPA-G supported with 15.1(1)T or later
• HWIC-3G-CDMA-S supported with 15.0(1)M1 or later
• HWIC-3G-CDMA-V supported with 15.0(1)M1 or later
• HWIC-3G-CDMA-B supported with 15.0(1)M1 or later
• HWIC-3G-CDMA-T supported with 15.0(1)M1 or later
• HWIC-3G-CDMA-R supported with 15.0(1)M1 or later
• HWIC-3G-CDMA=(spare only) supported with 15.0(1)M1 or later
Modem information ...
• Modem form factor: Embedded Peripheral Component Interconnect (PCI) minicard
• HWIC-3G-HSPA: Sierra Wireless MC8790 (non-US market)
• HWIC-3G-HSPA-A**: Sierra Wireless MC8790 (US market)
• HWIC-3G-HSPA-G: Sierra Wireless MC8792V (non-US market)
• HWIC-3G-CDMA-S: Sierra Wireless MC5727
• HWIC-3G-CDMA-V: Sierra Wireless MC5727
• HWIC-3G-CDMA-B: Sierra Wireless MC5727
• HWIC-3G-CDMA-T: Sierra Wireless MC5727
• HWIC-3G-CDMA-R: Sierra Wireless MC5727
Thanks in advance,
Mladen
Hello Mladen,
>> As I am in Europe, the correct one would be "HWIC-3G-HSPA-G"?
yes your understanding is correct think of G = GSM
Hope to help
Giuseppe
mladentsvetkov
One other difference is the following:
"Frequency bands supported:
HWIC-3G-HSPA
• 850-, 1900-, and 2100-MHz WCDMA bands (HSUPA, HSDPA and UMTS)
• 850-, 900-, 1800-, 1900-MHz GSM bands (EDGE and GPRS)
HWIC-3G-HSPA-G
• 900-, 1900-, and 2100-MHz WCDMA bands (HSUPA, HSDPA and UMTS)
According to "http://en.wikipedia.org/wiki/UMTS_frequency_bands#cite_note-0", the 900 band is used in Europe and the 850 band is used in the US.
Mladen
Hello Mladen,
Hope to help
Giuseppe
