04-12-2016
10:25 AM
- last edited on
03-25-2019
03:46 PM
by
ciscomoderator
I have configured HWIC 3G cellular interface on a 1841 router.
When I reload the router the interface get an IP address and traffic pass to internet, but after sometime the cellular interface is reseting and the interface is is not having any ip address no traffic pass .
Im attaching the router configuration please help me on this.
04-12-2016 09:25 PM
Nothing attached. Also what IOS version are you using?
04-13-2016 12:54 AM
The IOS version is Version 15.1(4)M5 and below is the router configuration.
version 15.1
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
chat-script gsm "" "ATDT*98*1#" TIMEOUT 60 "CONNECT"
license udi pid CISCO1841 sn FCZ1537C63D
redundancy
controller Cellular 0/0
crypto isakmp policy 1
encr aes 256
hash sha256
authentication pre-share
group 2
lifetime 3600
crypto isakmp key pont3g address 46.218.138.2
crypto ipsec transform-set pont3g esp-aes 256 esp-sha512-hmac
no crypto ipsec nat-transparency udp-encapsulation
crypto map pont3g 10 ipsec-isakmp
set peer 46.218.138.2
set transform-set pont3g
match address VPN-Traffic
interface FastEthernet0/0
ip address 10.128.98.1 255.255.255.0
ip virtual-reassembly in
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.0.10 255.255.255.0
duplex auto
speed auto
crypto map pont3g
interface ATM0/1/0
no ip address
shutdown
no atm ilmi-keepalive
interface Cellular0/0/0
ip address negotiated
encapsulation ppp
dialer in-band
dialer idle-timeout 0
dialer string gsm
dialer-group 1
async mode interactive
ppp authentication pap callin
ppp eap refuse
ppp chap refuse
ppp ms-chap-v2 refuse
ppp pap sent-username sfr password 0 sfr
ppp ipcp dns request
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 Cellular0/0/0
ip access-list extended VPN-Traffic
permit ip 10.128.98.0 0.0.0.255 172.24.0.0 0.0.255.255
permit ip 10.128.98.0 0.0.0.255 10.1.13.0 0.0.0.255
access-list 1 permit any
dialer-list 1 protocol ip permit
control-plane
line con 0
line aux 0
line 0/0/0
exec-timeout 0 0
password sfr
script dialer gsm
login
modem InOut
no exec
transport preferred none
transport output none
rxspeed 3600000
txspeed 384000
line vty 0 4
login
transport input all
04-13-2016 01:15 PM
Are you able to upgrade to the gold star release 15.1.4M10 ?
04-14-2016 02:37 AM
I have upgraded on 15.1.4M10 now it is worst, the interface gets up, after that immediately resetting and then going down.
*Apr 14 09:46:04.523: %LINK-3-UPDOWN: Interface Cellular0/0/0, changed state to up
*Apr 14 09:46:06.587: %LINK-5-CHANGED: Interface Cellular0/0/0, changed state to reset
*Apr 14 09:46:11.587: %LINK-3-UPDOWN: Interface Cellular0/0/0, changed state to
Thanks for your help.
04-14-2016 02:02 PM
Wow that is a bad reaction. Try powering the router down, remove and re-insert the HWIC card (re-seating the card) and then power back on.
The 3G modem is not acting like it is very happy.
04-15-2016 05:15 AM
I have powerd off the router re inserted the card but it is still the same.
Even i have performed a modem upgrade nothing changed .
04-17-2016 01:06 PM
I don't think you should have "password sfr" on line 0/0/0. That line is used by the router to talk to the 3G modem. Try removing it.
Perhaps try changing:
to:
ip route 0.0.0.0 0.0.0.0 Cellular0/0/0 permanent
04-20-2016 07:18 AM
I have modified the default route as you said, but nothing changed.
When i restart the router i get below message:
*Apr 20 14:26:04.727: %CELLWAN-2-MODEM_UP: Modem in HWIC slot 0/0 is now UP
As soon as i try to ping 8.8.8.8 i get below messages.
*Apr 20 14:29:54.067: Ce0/0/0 DDR: place call
*Apr 20 14:29:54.067: Ce0/0/0 DDR: Dialing cause ip (s=10.128.98.1, d=8.8.8.8)
*Apr 20 14:29:54.067: Ce0/0/0 DDR: Attempting to dial gsm
*Apr 20 14:29:54.067: CHAT0/0/0: Attempting async line dialer script
*Apr 20 14:29:54.067: CHAT0/0/0: Dialing using Modem script: gsm & System script: none
*Apr 20 14:29:54.071: CHAT0/0/0: process started
*Apr 20 14:29:54.071: CHAT0/0/0: Asserting DTR
*Apr 20 14:29:54.071: CHAT0/0/0: Chat script gsm started
*Apr 20 14:29:54.071: CHAT0/0/0: Sending string: ATDT*98#
*Apr 20 14:29:54.071: CHAT0/0/0: Expecting string: CONNECT
*Apr 20 14:29:54.123: CHAT0/0/0: Completed match for expect: CONNECT
*Apr 20 14:29:54.123: CHAT0/0/0: Chat script gsm finished, status = Success.
*Apr 20 14:29:56.123: %LINK-3-UPDOWN: Interface Cellular0/0/0, changed state to up
*Apr 20 14:29:56.123: Ce0/0/0 DDR: Dialer statechange to up
*Apr 20 14:29:56.123: Ce0/0/0 DDR: Dialer call has been placed
*Apr 20 14:29:56.167: Ce0/0/0 PPP: Using dialer call direction
*Apr 20 14:29:56.167: Ce0/0/0 PPP: Treating connection as a callout
*Apr 20 14:29:56.167: Ce0/0/0 PPP: Session handle[41000001] Session id[1].
*Apr 20 14:29:58.199: %LINK-5-CHANGED: Interface Cellular0/0/0, changed state to reset...
Success rate is 0 percent (0/5)
Router#
*Apr 20 14:30:03.199: %LINK-3-UPDOWN: Interface Cellular0/0/0, changed state to down
*Apr 20 14:30:13.199: Ce0/0/0 DDR: re-enable timeout
04-20-2016 08:02 AM
hi,
could you change the chat-script below to "OK" and try again?
chat-script gsm "" "ATDT*98*1#" TIMEOUT 60 "OK"
04-20-2016 08:08 AM
I have modified as you said, but nothing changed.
chat-script gsm "" "ATDT*98#" TIMEOUT 60 "OK"
*Apr 20 15:17:58.867: Ce0/0/0 DDR: place call
*Apr 20 15:17:58.867: Ce0/0/0 DDR: Dialing cause ip (s=10.128.98.1, d=8.8.8.8)
*Apr 20 15:17:58.867: Ce0/0/0 DDR: Attempting to dial gsm
*Apr 20 15:17:58.867: CHAT0/0/0: Attempting async line dialer script
*Apr 20 15:17:58.867: CHAT0/0/0: Dialing using Modem script: gsm & System script: none
*Apr 20 15:17:58.871: CHAT0/0/0: process started
*Apr 20 15:17:58.871: CHAT0/0/0: Asserting DTR
*Apr 20 15:17:58.871: CHAT0/0/0: Chat script gsm started
*Apr 20 15:17:58.871: CHAT0/0/0: Sending string: ATDT*98#
*Apr 20 15:17:58.871: CHAT0/0/0: Expecting string: OK.....
Router#
Router#
*Apr 20 15:18:58.871: CHAT0/0/0: Timeout expecting: OK
*Apr 20 15:18:58.871: CHAT0/0/0: Chat script gsm finished, status = Connection timed out; remote host not responding
*Apr 20 15:18:58.871: Ce0/0/0 DDR: disconnecting call
*Apr 20 15:19:13.871: Ce0/0/0 DDR: re-enable timeout
04-20-2016 09:58 AM
normally it should look like this.
(this is lte 4G stuff so it is a little different)
attach profile under controller cellular first
lte sim data-profile 1 attach-profile 1 slot 0
lte gps mode standalone
lte gps nmea
configure chat script
chat-script lte "" "AT!CALL" TIMEOUT 20 "OK"
interface Cellular0
encapsulation slip
dialer in-band
dialer string lte
dialer-group 2
dialer-list 2 protocol ip permit
ping to the outside when debug is activated. This should do it.
Kind Regards
Jan Meylaers
04-22-2016 12:14 AM
Thanks for replay, but under controller cellular 0 i dont see the option lte.
Router(config-controller)#?
Controller configuration commands:
default Set a command to its defaults
description Controller specific description
exit Exit from controller configuration mode
gsm GSM type carrier
help Description of the interactive help system
no Negate a command or set its defaults
04-26-2016 04:57 AM
you do not need the lte command as you are having a 3G router.
I have found a 3G router configuration.
cellular 0 gsm profile create 15 addrprovider optionpwd
chat-script GSM "" "AT!SCACT=1,15" TIMEOUT 60 "OK"
controller Cellular 0 gsm sim profile 15 slot 1 gsm gps mode standalone gsm gps nmea
interface Cellular0 ip address negotiated ip nat outside ip virtual-reassembly in encapsulation slip dialer in-band dialer pool-member 1 dialer-group 1
interface Dialer0 ip address negotiated ip nat outside ip virtual-reassembly in encapsulation slip dialer pool 1 dialer idle-timeout 0 dialer string GSM dialer persistent dialer-group 1
ip route 0.0.0.0 0.0.0.0 Dialer0
line 3 script dialer GSM no exec rxspeed 21600000 txspeed 5760000 line 6 modem InOut no exec
07-22-2016 02:01 AM
Hellow,
I have a Cisco router 1841 with a HWIC 3g card.
I have configured site to site VPN with a cisco ASA, the configuration is working well but I have very high latency around 400 to 500 ms.
When i reboo the router the latency is around 100 ms for some minutes and then insreases, even the traffic is not increasing the latency insrease after some minutes.
Below is the router configuration :
Current configuration : 6330 bytes
! Last configuration change at 14:21:45 UTC Wed Jul 20 2016
version 15.1
hostname P3g-AHR-Amiens
boot-start-marker
boot system flash c1841-adventerprisek9-mz.151-4.M10.bin
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip domain name as.asd.asf
ip name-server 8.8.4.4
ip name-server 8.8.8.8
ip ddns update method pont3G
HTTP
add http://pont3g:pont3G@dynupdate.no-ip.com/nic/updatehostname=<h>&myip=<a>
interval maximum 0 0 0 5
no ipv6 cef
license udi pid CISCO1841 sn FHK09362129
log config
hidekeys
redundancy
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh port 4022 rotary 1
ip ssh source-interface FastEthernet0/0
ip ssh version 2
encr aes 256
group 2
lifetime 3600
crypto isakmp key pont3g address 62.160.183.247
crypto isakmp keepalive 3600
crypto ipsec transform-set pont3g esp-aes 256 esp-sha-hmac
crypto map pont3g 1 ipsec-isakmp
set peer 62.160.183.247
description *** VLAN CLIENT ***
ip address 10.128.32.4 255.255.255.0
ip nat inside
duplex auto
speed auto
vrrp 1 ip 10.128.162.1
vrrp 1 priority 80
vrrp 5 ip 10.128.32.1
vrrp 5 priority 80
no ip address
shutdown
duplex auto
speed auto
interface ATM0/1/0
no ip address
shutdown
ip ddns update hostname p3g-ahr.ddns.net
ip ddns update pont3G
ip nat outside
no ip virtual-reassembly in
encapsulation ppp
dialer in-band
dialer string gsm
dialer-group 1
ppp chap hostname orange
ppp chap password 0 orange
crypto map pont3g
no ip http server
ip nat inside source list 2000 interface Cellular0/0/0 overload
ip route 10.128.33.0 255.255.255.0 10.128.32.254
ip route 10.128.228.0 255.255.255.192 10.128.32.254
permit ip 10.128.33.0 0.0.0.127 10.129.0.0 0.0.127.255
permit ip 10.128.33.0 0.0.0.127 10.130.0.0 0.0.255.255
permit ip 10.128.33.0 0.0.0.127 10.66.27.0 0.0.0.255
permit ip 10.128.33.0 0.0.0.127 10.66.28.0 0.0.0.255
permit ip 10.128.33.0 0.0.0.127 10.134.9.0 0.0.0.255
permit ip 10.128.33.0 0.0.0.127 172.31.0.0 0.0.0.255
permit ip 10.128.228.0 0.0.0.63 10.129.0.0 0.0.127.255
permit ip 10.128.228.0 0.0.0.63 10.130.0.0 0.0.255.255
permit ip 10.128.228.0 0.0.0.63 10.66.27.0 0.0.0.255
permit ip 10.128.228.0 0.0.0.63 10.66.28.0 0.0.0.255
permit ip 10.128.228.0 0.0.0.63 10.134.99.0 0.0.0.255
permit ip 10.128.228.0 0.0.0.63 172.31.0.0 0.0.0.255
permit ip 10.128.32.0 0.0.0.255 10.129.0.0 0.0.127.255
permit ip 10.128.32.0 0.0.0.255 10.130.0.0 0.0.255.255
permit ip 10.128.32.0 0.0.0.255 10.66.27.0 0.0.0.255
permit ip 10.128.32.0 0.0.0.255 10.66.28.0 0.0.0.255
permit ip 10.128.32.0 0.0.0.255 10.134.99.0 0.0.0.255
permit ip 10.128.32.0 0.0.0.255 172.31.0.0 0.0.0.255
permit ip 10.128.33.128 0.0.0.127 10.129.0.0 0.0.127.255
permit ip 10.128.33.128 0.0.0.127 10.130.0.0 0.0.255.255
permit ip 10.128.33.128 0.0.0.127 10.66.27.0 0.0.0.255
permit ip 10.128.33.128 0.0.0.127 10.66.28.0 0.0.0.255
permit ip 10.128.33.128 0.0.0.127 10.134.99.0 0.0.0.255
permit ip 10.128.33.128 0.0.0.127 172.31.0.0 0.0.0.255
permit ip 10.128.33.0 0.0.0.127 10.130.20.0 0.0.0.255
permit ip 10.128.228.0 0.0.0.63 10.130.20.0 0.0.0.255
permit ip 10.128.32.0 0.0.0.255 10.130.20.0 0.0.0.255
permit ip 10.128.33.128 0.0.0.127 10.130.20.0 0.0.0.255
ip sla 1
icmp-echo 8.8.8.8 source-interface Cellular0/0/0
frequency 5
ip sla schedule 1 life forever start-time now
access-list 2000 deny ip 10.128.33.0 0.0.0.127 10.129.0.0 0.0.127.255
access-list 2000 deny ip 10.128.33.0 0.0.0.127 10.130.0.0 0.0.255.255
access-list 2000 deny ip 10.128.33.0 0.0.0.127 10.66.27.0 0.0.0.255
access-list 2000 deny ip 10.128.33.0 0.0.0.127 10.66.28.0 0.0.0.255
access-list 2000 deny ip 10.128.33.0 0.0.0.127 10.134.9.0 0.0.0.255
access-list 2000 deny ip 10.128.33.0 0.0.0.127 172.31.0.0 0.0.0.255
access-list 2000 deny ip 10.128.228.0 0.0.0.63 10.129.0.0 0.0.127.255
access-list 2000 deny ip 10.128.228.0 0.0.0.63 10.130.0.0 0.0.255.255
access-list 2000 deny ip 10.128.228.0 0.0.0.63 10.66.27.0 0.0.0.255
access-list 2000 deny ip 10.128.228.0 0.0.0.63 10.66.28.0 0.0.0.255
access-list 2000 deny ip 10.128.228.0 0.0.0.63 10.134.99.0 0.0.0.255
access-list 2000 deny ip 10.128.228.0 0.0.0.63 172.31.0.0 0.0.0.255
access-list 2000 deny ip 10.128.32.0 0.0.0.255 10.129.0.0 0.0.127.255
access-list 2000 deny ip 10.128.32.0 0.0.0.255 10.130.0.0 0.0.255.255
access-list 2000 deny ip 10.128.32.0 0.0.0.255 10.66.27.0 0.0.0.255
access-list 2000 deny ip 10.128.32.0 0.0.0.255 10.66.28.0 0.0.0.255
access-list 2000 deny ip 10.128.32.0 0.0.0.255 10.134.99.0 0.0.0.255
access-list 2000 deny ip 10.128.32.0 0.0.0.255 172.31.0.0 0.0.0.255
access-list 2000 deny ip 10.128.33.128 0.0.0.127 10.129.0.0 0.0.127.255
access-list 2000 deny ip 10.128.33.128 0.0.0.127 10.130.0.0 0.0.255.255
access-list 2000 deny ip 10.128.33.128 0.0.0.127 10.66.27.0 0.0.0.255
access-list 2000 deny ip 10.128.33.128 0.0.0.127 10.66.28.0 0.0.0.255
access-list 2000 deny ip 10.128.33.128 0.0.0.127 10.134.99.0 0.0.0.255
access-list 2000 deny ip 10.128.33.128 0.0.0.127 172.31.0.0 0.0.0.255
access-list 2000 permit ip 10.128.33.0 0.0.0.127 any
access-list 2000 permit ip 10.128.228.0 0.0.0.63 any
access-list 2000 permit ip 10.128.32.0 0.0.0.255 any
access-list 2000 permit ip 10.128.33.128 0.0.0.127 any
dialer-list 1 protocol ip list 2000
control-plane
line con 0
line aux 0
line 0/0/0
exec-timeout 0 0
script dialer gsm
modem InOut
no exec
rxspeed 3600000
txspeed 384000
line vty 0 4
login local
transport input all
scheduler allocate 20000 1000
ntp server 138.96.64.10
ntp server 195.220.94.163
end
Can anyone help me please to find the root cause.
thanks,
