%HWIC_HOST-1-RX_OVERRUN_ERROR: HWIC_HOST: Host termination logic experienced a Receive FIFO overrun for Interface Descriptor Block
CHRISTIAN END
i see the following log output. I searched for it and updated the IOS on our 2901 ISR. But the issue will not disappear. It came back after some hours.
Has someone an idea if it could be a hardware issue? And if it is, what hardware?
The error:
The IOS:
c2900-universalk9-mz.SPA.155-3.M5.bin
The Inventory:
NAME: "CISCO2901/K9", DESCR: "CISCO2901/K9 chassis, Hw Revision: 1.0"
PID: CISCO2901/K9 , VID: V06
NAME: "VWIC3-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 0", DESCR: "VWIC3-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC3-1MFT-T1/E1 , VID: V01
NAME: "2nd generation two port BRI voice interface daughtercard on Slot 0 SubSlot 1", DESCR: "2nd generation two port BRI voice interface daughtercard"
PID: VIC2-2BRI-NT/TE , VID: V03
NAME: "3rd generation four port FXS DID voice interface daughtercard on Slot 0 SubSlot 2", DESCR: "3rd generation four port FXS DID voice interface daughtercard"
PID: VIC3-4FXS/DID , VID: V03
NAME: "PVDM3 DSP DIMM with 16 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 16 Channels"
PID: PVDM3-16 , VID: V01
NAME: "PVDM3 DSP DIMM with 32 Channels on Slot 0 SubSlot 5", DESCR: "PVDM3 DSP DIMM with 32 Channels"
PID: PVDM3-32 , VID: V01
NAME: "C1941/C2901 AC Power Supply", DESCR: "C1941/C2901 AC Power Supply"
PID: PWR-1941-2901-AC , VID:
Thanks for you help.
Christian
0 Replies 0
