I cannot Click on "Additiinal Task" tab on SDM, to add DNS entries ?
vikramdeshmukh2
I have 1841 router, SDM is installed but FA 0/0 is connected to ISP modem, and FA 0/1 is connected to intern/w through a linksys switch, given ip address as per the interfaces
Interface                        IP-Address      OK? Method           Status                                Protocol
FastEthernet0/0            113.X.X.X          YES NVRAM            up                                    up
FastEthernet0/1            192.168.10.2    YES NVRAM             up                                    up
Serial0/0/0                    unassigned      YES NVRAM             administratively down         down
NVI0                             unassigned      NO  unset                 up                                      up
Loopback0                    unassigned      YES NVRAM             up                                     up
Building configuration...
Current configuration : 1383 bytes
version 12.4
service password-encryption
hostname //Hidden
boot-start-marker
boot-end-marker
l
interface Loopback0
no ip address
interface FastEthernet0/0
description $ETH-WAN$
ip address 113.X.X.X //Hidden 255.255.255.0
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
description $ETH-LAN$
ip address 192.168.10.2 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
clock rate 2000000
router rip
version 2
network 113.0.0.0
network 192.168.10.0
no auto-summary
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
ip http server
ip http authentication local
no ip http secure-server
ip nat inside source list 1 interface FastEthernet0/0 overload
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.168.10.0 0.0.0.255
control-plane
line con 0
password 7 //Hidden
login
line aux 0
password 7  //Hidden
login
line vty 0 4
privilege level 15
password 7 //Hidden
login local
transport input telnet
scheduler allocate 20000 1000
end
from my pc which is 192.168.10.44 i can ping 192.168.10.2 (fa 0/1 interface of router ) but cannot ping 4.2.2.2 or any internet, hence i wanted to add static DNS entries but i don't know the commands on cli, hence tried to add through SDM but "additional task" tab is disabled ...
Any ideas what to do next...
Thanks in advance.
vikram
kyukim
  hi,
If you want to make your router to use internet dns server or make it as DNS forwarder, you do it by "ip dns server" "ip name-server xxxx".
Then, you can add A record to IOS dns server with "ip host test x.x.x.x"
Your NAT config looks good so your PC should ping 4.2.2.2 fine.
would you try "ping 4.2.2.2 source f0/1" and type "sh ip nat trans" from router CLI?
KK
On your pc have you put the correct gateway or mask in your ip config ?
If you can't ping  L3 addresses, dns won't help you much.
For your additional task issue this is a problem with Java ( which version of jre have you got? try to downgrade to 1.6.0.3).
xabrouck
To see 'additional task' in SDM, you need to downgrade your JVM.
According to http://www.cisco.com/en/US/docs/routers/access/cisco_router_and_security_de​vice_manager/software/release/notes/SDMr25.html#wp35379​
The following versions are supported:
*JRE 1.5_09
*JRE1.4.2_08
*JRE 1.5.0_06
*JRE 1.5.0_07
*JRE 1.6.0_02
*JRE 1.6.0_03
SDM is deprecated now, it's better to use CCP http://www.cisco.com/go/ccp
Xavier
