I have cisco core switch 4507R
CSCO11678473
Hello my dear brothers,
Can any one please tell me the DHCP configuration on CISCO core switch 4507R switch.With one vlan and multipul vlan both configuration using any ip address range.
Marwan ALshawi
Ip dhcp exlude-address x.x.x.x. This to exclude address or address range such as the default gate way
Ip dhcp pool poolname
Network 10.1.1.0 /24
Default-router 10.1.1.1
If uhave multiple vlans just create same conga as above fir each vlan/network
Good luck
If helpful rate
One more thing  i have one office no branchs office so doing Dhcp service in core switch is better or on Router or on windows server  less then 100 users.
Hi AMir,
Running DHCP service on switch/Router will help you reduce the number of devices to manage, while running DHCP in a standalone server will help with scalability.
HTH,
Nagendra
