I HAVE PROBLEM FOR UP MY DATA LINK
utrujillo
I THAT ENYBODY HELP ME, I CAN?T UP THE LINE PROTOCOL OF MY DATA LINK, I CHANGED THE SLOT AND NOTHING HAPPEND, I CHANGED THE CABLE V.35 AND NOTHING HAPPEND, THE PROTOCOL THAT I MANNAGE IS HDLC
Serial0 is up, line protocol is down
pciaccio
Level 4
Level 4
You need to provide to us further information. How are you configured on the router? Provide a SHOW INTERFACE command results to assist us in helping you. Also the configuration of the remote end will help as well....
Can you ask your ISP to give a Lookp from His end to your Router ?
After that when you check your link status
you should get a message saying Looped.
If there is a problem with the Line, then he will automatically come to know from his loop equipment
HTH pls rate all useful posts
