I need a static route help
hfakoor222
I need a static route to be able to ping Loopback0 on R2 from R1. I do not want a default route but something more specific pointting to the loopback address or subnet. I want to save the default route for something else.  I dont wan't this by injecting OSPF into R2. I am asking if theres a possibility to reach Loopback0 from R1 using static routes that are not default
R1
R1 Config
Current configuration : 1446 bytes
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
archive
log config
hidekeys
ip tcp synwait-time 5
interface Loopback0
ip address 64.100.10.1 255.255.255.0
interface FastEthernet0/0
ip address 10.0.1.1 255.255.255.0
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
clock rate 2000000
interface FastEthernet0/1
ip address 10.2.0.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet1/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet2/0
no ip address
shutdown
duplex auto
speed auto
router ospf 1
router-id 1.1.1.1
log-adjacency-changes
area 2 stub no-summary
network 10.0.1.0 0.0.0.255 area 0
network 10.2.0.0 0.0.0.255 area 2
default-information originate always
ip forward-protocol nd
no ip http server
no ip http secure-server
no cdp log mismatch duplex
control-plane
banner motd ^C This is R1, Trouble Ticket 8.1.2.1 ^C
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
R2   Config
Current configuration : 1386 bytes
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
archive
log config
hidekeys
interface Loopback0
ip address 10.2.1.1 255.255.255.0
ip ospf network point-to-point
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
clock rate 2000000
ip address 10.2.0.2 255.255.255.0
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
router ospf 1
router-id 2.2.2.2
network 10.2.1.0 0.0.0.255 area 2
ip route 0.0.0.0 0.0.0.0 10.2.0.1
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
the most 'restrictive' static route would be a host route on R1:
R1
ip route 10.2.1.1 255.255.255.255 10.2.0.1
paul.driver
Hello
R2
router ospf 1
no network 10.2.1.0 0.0.0.255 area 2
R1
ip route 10.2.1.0 255.255.255.0 fa0/1 10.2.0.2
R1
