I need urgent help please in packet tracer
h00384864
Guys, look, here he has two networks and three routers, but I can't ping the other network, I don't know why, is there any help please?
6 Accepted Solutions
post your zipped Packet Tracer project (.pkt) file, and indicate which version of Packet Tracer you are using...
what instructions are you following ? Your routers have no routing (static or dynamic) configured, the IP addressing on the WAN interfaces is wrong/duplicate, and the LAN IP addressing is wrong/duplicate as well.
it depends on the requirements. You can use static routing, or a dynamic routing protocol (RIPv2/EIGRP/OSPF). You also need to decide what IP addressing scheme you want (or have) to use. Is this project based on specific instructions ?
I tried to use the RIP protocol, but it didn't work for me. Just wait for me to get home. I will upload the file to you after my last modification. He now has 3 networks, 3 regular routers and one wireless router.
My friend, when I upload the new file to you, I want you to look at it if possible and tell me all its problems and how I can solve them myself.
sure, send the new file. The most important thing is the IP addressing, you need to make sure that there are no duplicate IP addresses anywhere.
21 Replies 21
h00384864
Please I need help
This is a special package trace file
How well can these problems be solved?
My friend, how can we solve this problem?
At first, I am very sorry for the delay in replying to you and uploading the file to you, but I was in the hospital, so I am very sorry for the delay
And this is the file. I uploaded it to you. Did you correct it for me and then send it back to me so that I can see for myself what I did and learn it myself?
attached the revised file. Keep in mind that you need unique subnets between the routers, and also unique networks/subnets on all other interfaces. I had to change a lot of the IP addressing, it is all arbitrary since I do not know which specific IP addressing scheme you are supposed to use.
Ok, thank you, I will try the file you gave me and I will get back to you with good news
It doesn't deliver ping , I don't know why
