Hi Ayman,
it looks like this device is configured with 'no service password-recovery' and hence, access to rommon is denied.
Additionally, it also looks like there is either a corrupted or no IOS image on the flash and hence, it may be that this device fails to boot.
The following link explains this behavior:
http://www.cisco.com/en/US/products/hw/routers/ps274/products_configuration_example09186a00801d8113.shtml
The only solution for this is also described on this page:
If a router is configured with the no service password-recovery command, this disables all access to the ROMMON. If there is no valid Cisco IOS software image in the Flash memory of the router, the user is not able to use the ROMMON XMODEM command in order to load a new Flash image. In order to fix the router, you must get a new Cisco IOS software image on a Flash SIMM, or on a PCMCIA card, for example on the 3600 Series Routers.
HTH,
Bert
