I want to access my public IP address from inside my Lan network
i have a Local area network with ip address 177.100.0.0 255.255.0.0 and i have a Cisco Router ASA 5510 series.
i have a fix public IP on this router (ex 123.321.123.321) with a https port (44344) to be accessed from inside network (ex: 123.321.123.321:44344 should give me back 177.100.0.2 (wish is my server where the https is located).
from outside i was able to access this server by using its public ip add, also i can access it from inside network using its lan ip add 177.100.0.2:44344 but when i try to access the public ip (123.321.123.321:44344) from inside network it fails.
can anyone help me using ASDM GUI interface how to configure the Nat rule and the access rule?
i appreciate any help
thank you in advance.
I guess what you need is NAT hairpinning on your ASA. I have googled around for a document that describes how to do that via ASDM, check the one below:
https://www.cyrio.co.uk/tips/cisco/asa-hairpinning/
Thank you so much it worked perfectly
I appreciate it
