iBGP and EBGP
shahzad.rasheed
I am facing a problem regarding routing between iBGP and eBGP.
Within my AS i am using iBGP and with my provider EBGP, routes learned via iBGP are not being advertised to my provider by EBGP. My gateway router has all routes in its routing table learnt by iBGP but EBGP is not advertising these routes. I have given the Network command but no use.
Please help...Thanks.
Shahzad Rasheed, Dancom Online Pakistan.
7 Replies 7
attrgautam
Level 5
Level 5
Can you show the configuration at ur end and at your upstream end ?
Here is the configuration of my GW ,
router bgp xxxx
no synchronization
bgp router-id xxxxx
no bgp default ipv4-unicast
bgp log-neighbor-changes
neighbor xxx.125.xxx.137 remote-as xxxx
neighbor xxx.125.xxx.137 description PTCL
neighbor xxx.125.xxx.137 update-source Loopback0
neighbor xxx.xxx.176.251 remote-as xxxxx
neighbor xxx.xxx.176.251 description XXXISB
neighbor xxx.xxx.176.251 update-source Loopback3
no auto-summary
address-family ipv4
neighbor xxx.125.xxx.137 activate
neighbor xxx.125.xxx.137 soft-reconfiguration inbound
neighbor xxx.125.xxx.137 distribute-list PERMIT_TO_PTCL out
neighbor xxx.xxx.176.251 activate
neighbor xxx.xxx.176.251 soft-reconfiguration inbound
neighbor xxx.xxx.176.251 prefix-list PERMIT_FROM_XXXISB in
neighbor xxx.xxx.176.251 prefix-list PERMIT_TO_XXXISB out
no auto-summary
no synchronization
network xxx.xxx.12.0
network xxx.xxx.13.0
network xxx.xxx.15.0
network xxx.xxx.17.0
network xxx.xxx.18.0
network xxx.xxx.19.0
network xxx.xxx.10.0
network xxx.xxx.11.0
network xxx.xxx.174.0
network xxx.xxx.177.0
network xxxx.9.61.0
network xxx.9.62.0
network xxx.2.89.0
exit-address-family
I dont have access of my ustream provider router.
Thanx.
Is it possible that the distribute-list applied outbound toward the SP could be blocking the advertisement of these prefixes.
Hope this helps,
Can you check the status of your BGP ? Whether you are able to advertise any routes and able to receive any ? Also can u print your prefix/distribute lists?
Hi Shahzad,
As per thumb rule of BGP, for a prefix to advertise via EBGP, there should be a exact match route for that prefix in IGP routing table.Which IGP you are using?
I afraid i read this query completely..Please igone my answer for this query.
thanks a lot to every one who contirbuted ... problem is resolved and it was distrbute list :$.
