iBGP Full Mesh Routing Problem
davidhuynh5
I've setup a iBGP full mesh and configured o-hst-cr-re01 as a route reflector client, but still can not ping 10.84.18.5 (ASN 64555) from o-hst-cr-re01. What am I doing wrong? Any help would be appreciated. Thank You.
8 Replies 8
Jon Marshall
Follow normal troubleshooting procedure.
Are the routes in the BGP table and the IP routing tables in each of the routers in the path.
How far does a traceroute get from the source to the destination ?
Jon
chrihussey
A lot to look at here but:
1- You have o-hst-cr-re01 configured as a route-reflector client to o-ew-cr-re01, yet o-hst-cr-re01 is IBGP peering with the other two routers in the AS. It shouldn't be that way. The o-hst-cr-re01 should just peer with o-ew-cr-re01, and not the others if it is to be a route reflector client.
2- Aside from that, it would probably best if it were to be a client to a directly connected peer and not one a couple hops away.
3- You could also have it be a client to the o-ee-cr-re01 and o-sa26-cr-re01 routers and use a cluster ID. Again if doing it that way, it wouldn't IBGP peer with o-hst-cr-re01.
Hope this helps
1- Agreed. I was try to build a full ibgp mesh, hoping that 10.84.18.1 (ASN 64999) could reach 10.84.18.5 (ASN 64555). It did not work, so I made 10.84.18.1 a RR client and 10.84.18.5 was still unreachable.
2. I not sure what you mean/
3. I will try that.
Thank You.
post the full config of the route reflector and the full config of o-ew-hb-re05 (in ASN 64555) as well...
sivam siva
Level 3
Level 3
The issue is o-ew-hb-re05  Don't know how to reach the o-hst-cr-re01 (10.84.18.1).
In your scenario o-ee-cr-re01 and o-sa26-cr-re01 doesn't send the 10.84.18.1 route to o-ew-cr-re01, because those routers learning that route from o-hst-cr-re01 so it will not send to  any other IBGP peer as per BGP split horizon rule. then how o-ew-hb-re05 knows about 10.84.18.1 ?!!
to get this resolve configure "neighbor 10.84.18.13 route-reflector-client" in o-ee-cr-re01 and o-sa26-cr-re01 (but this is not a best practices) then those routers send the 10.84.18.1 route to o-ew-cr-re01 as a BGP advertisement.
I configured 10.84.18.13 to be a RR client as suggested but still unable to ping 10.84.18.5 from 10.84.18.1.
davidhuynh5
Hey guys, I didn't advertise the WAN link between o-hst-cr-re01 and o-sa26-cr-re01 into iBGP...duh. I have reachablity to 10.84.18.5 now. Thanks for all your help.
Are you able to reach without configure command (neighbor 10.84.18.13 route-reflector-client) what I told ?
