ICRL redundancy link
yingjiecisco
Has anyone heard of or used ICRL on cisco routers?
What configuration is required, or is it supported by default on any FastEthernet ports?
I have searched cisco website but didn't seem to find any reference on this topic.
Any input or advice is appreciated.
Cheers
Pavel Bykov
Level 5
Level 5
I never heard of it. Are you sure the abbreviation is correct?
yep... ICRL probably stands for "Inter-Chassis Redundancy Link".
I found some reference to ICRL on Nortel and IBM servers (by google), and wonder if it is supported on cisco routers by default.
