If 2 routers have 2 subnets common to them and ospf is configured on both, how does ospf priorities/balance traffic over the 2 subnets?
LondonCisco
Hi All
We have 3 routers in our infrastructure (say R1, R2 & R3). All 3 are connected using OSPF, plus all 3 have external bgp connections. The OSPF is used as iBGP (if this is the correct terminology) i.e. R1 has some routes in the routing table to R2 and R3.
Our routers are all connected together using 2 ospf connections i.e. R1 and R3 have 2 subnets common to each other over which ospf is configured.
R1 and R3 are in different data centres, therefore the 2 subnets over which the ospf connects are vlans provided by 2 different 3rd parties. One of the 3rd parties has more problems with disruptions on its vlan, the other being pretty problem free. Therefore, I would like to know the following. Could anybody help?
a) I'm not sure how ospf works with 2 connections. For example, say R1 has a entry in its routing table for R3. Which of the 2 ospf subnets will the traffic be sent down? Will it (for want of a better phrase) be active-active or active-passive?
I show the output from the routing table that hopefully shows an entry via ospf from R1 to R3, the "sho ip cef" command showing the 2 vlans (M & N) which the ospf connects from R1 to R3. I have customised the output to protect parties!!! and put in <R?> to show to which device the ip address belongs to.
R1#sho ip cef X.X.X.X
X.0.0.0/11
  nexthop <R3>Y.Y.Y.58 GigabitEthernet0/0.M
  nexthop <R3>Y.Y.Y.62 GigabitEthernet0/1.N
R1#sho ip route X.X.X.X
Routing entry for X.0.0.0/11
  Known via "bgp PPPPP", distance 200, metric 0
  Tag RRRRR, type internal
  Last update from <R3>Y.Y.Y.40 4w0d ago
  Routing Descriptor Blocks:
  * Y.Y.Y.40, from Y.Y.Y.40, 4w0d ago
      Route metric is 0, traffic share count is 1
      AS Hops 2
      Route tag 2 RRRR
b) I ask as sometimes we have a disruption on one of the 2 connections which causes disruption on some of our traffic - I don't know if this is caused by a change in the routing table or whether it is just the switch having to update its mac table to send the traffic down the other vlan. Does anybody know if you would expect to see a disruption and why?
c) Is there a way to prioritise ospf traffic over vlan M (the one without problems) rather than vlan N, but to failover to vlan N if vlan M were to have problems?
Thanks in advance for all responses. I apologise if this isn't too clear and I will attempt to clarify things if anybody needs it.
Also, thanks to others who have responded to my previous posts, who may see that I'm using the information from them to inform my further queries!
John
cadet alain
OSPF is an IGP( Interior Gateway Protocol).
2)
X.0.0.0/11
  nexthop Y.Y.Y.58 GigabitEthernet0/0.M
  nexthop Y.Y.Y.62 GigabitEthernet0/1.N
You have 2 equal cost path to go to X.X.X.X and CEF will load-balance per src-dst IP pair.
3)
  Last update from Y.Y.Y.40 4w0d ago
      AS Hops 2
      Route tag 2 RRRR
This route is installed in the routing table as an iBGP route( AD of 200)
So this is an iBGP learned route and OSPF has 2 equal cost path to go to the next-hop because it can't be an OSPF route if it is an iBGP route.So I presumed OSPF is used to go to the next-hop and so the 2 routes are not  the same ?
for question b) I think the running-config and some show commands would be useful as well as explain what disruptions you have and when.
for question c)  just modify the cost of one link to make it a preferred one and if it goes down the traffic will follow the remaining link.
Regards.
Alain
cadet alain
2)
X.0.0.0/11
3)
      AS Hops 2
      Route tag 2 RRRR
Regards.
Alain
Hi Alain
Below is an extract from our running configuration of R1. I have only included the vlans/networks in the ospf section between R1 and R3 (which the original show ip route outputs referred to) and the ibgp and one external bgp within the bgp section.
The original output was taken from R1 and showed that the traffic was routed to R3 (via vlans M & N)
  • Y.Y.Y.0 are our ip addresses
  • Y.Y.Y.42 is the loopback for R1.
  • Y.Y.Y.41 is the loopback for R2.
  • Y.Y.Y.40 is the loopback for R3.
  • vlans M and N are the vlans over which ospf runs between R1 and R3.
  • You can see that R2 (Y.Y.Y.41) and R3 (Y.Y.Y.40) are configured within the R1 bgp as "peer-group ibgp".
I think I am confused as to the relationship between ospf and ibgp (if any!).
When I saw this output:
X.0.0.0/11
I assumed that as it was running over vlans M & N, that there was a relationship between the BGP and the OSPF. In fact, I assumed that (this could be total rubbish!):
R1 would build its routing table from its external bgp peers (there are 3) and then, via ospf, pick up any "better" routes from R2 and R3 - therefore R1 would have 5 possible "next hops" in its routing table, its 3 bgp peers and its 2 ospf peers.
Could you help with my understanding?
Finally, the issue is that vlan M is suffering some disruptions, whereas vlan N is not. Therefore I would like traffic to use vlan M rather than N, but be able to fail over to N if possible. I'm now very confused as to how both bgp and ospf traffic use these vlans!
If you could help, I would be very grateful. Also, if this is too time consuming, I understand and if you just have some links for reading -please let me know. Your help up to now is much appreciated as you are exposing holes in my understanding!
John
interface Loopback0
ip address Y.Y.Y.42 255.255.255.255
router ospf 1
router-id Y.Y.Y.42
log-adjacency-changes
redistribute connected subnets
redistribute static
passive-interface default
no passive-interface GigabitEthernet0/0.M
no passive-interface GigabitEthernet0/1.N
network Y.Y.Y.56 0.0.0.3 area 0
network Y.Y.Y.60 0.0.0.3 area 0
router bgp PPPPP
no synchronization
bgp always-compare-med
bgp log-neighbor-changes
bgp deterministic-med
network Y.Y.Y.0 mask 255.255.248.0
neighbor ibgp peer-group
neighbor ibgp remote-as PPPPP
neighbor ibgp update-source Loopback0
neighbor ibgp next-hop-self
neighbor ibgp soft-reconfiguration inbound
neighbor Z.Z.Z.Z remote-as RRRRR
neighbor Y.Y.Y.40 peer-group ibgp
neighbor Y.Y.Y.41 peer-group ibgp
no auto-summary
Hi Alain
Your comments put me to reading and I'm getting alot  better idea of ibgp, peergroups and ospf. Therefore, may I come back to  you in a few days when I have cleared up the issues I'm reading about.  I  will put this as answered as I think my original query had enough  mis-understandings to just confuse people.
John
no problem take your time to revise but please  don't put Xs or Ys everywhere in your IPs because we can't see which is which and so we can't answer you correctly, just change the values and stick it to it and be consistent.
Regards.
Alain
