IGX to IGX latency
om.v.verma
I want to check latency from my end igx to far end igx. can anybody tell me the command ?
Om
mheusing
The "tstdelay" command should do what you are looking for.
All technical details can be found in the command reference
http://www.cisco.com/en/US/products/sw/ps2346/ps99/products_command_reference_chapter09186a0080086f4f.html#wp1052348
Hope this helps! Please rate all posts.
Regards, Martin
