image download
stephtchoko
Level 3
Level 3
Good day,
I 'm finding where to download image c2600-jk2s-mz.12.0-2.T.bin but i can't find it. Is the location has changed ??
Please very emergency, i need help.
Regards.
Harold Ritter
This image is very outdated and is not downloadable from CCO anymore. I know that it might require a DRAM and SRAM upgrade but I would suggest going with a more recent image.
Hope this helps,
My router don't have a big DRAM/FLASK memory (32Mo/8Mo). Somebody ave this old image ??
You have all kinds of issues with that release.
It was a T release which means after 12.1 came out they did not update it. These get deferred very quickly.
As I'm sure you know all the newer releases with this feature set will not fit in your router.
Nobody can give you a copy because of license issues and this also contains DES3 so you are even more unlikely to get a copy because of import/export restriction.
