Implementing QoS for Voip on 2821 router
mulhollandm
folks
i have a 3750 switch running mls qos globally and then auto qos for cisco-phones & i need to setup the QoS on the router
i have a 2821 but haven't done this before
does anyone have a link to any decent config guides - i suspect it involves route-maps etc
thanks to anyone taking the time to reply
pkhatri
Level 11
Level 11
mheusinger
Level 10
Level 10
besides AutoQoS for VoIP, which Paresh pointed you to, there is also AUtoQoS for the Enterprise available now, which will allow you to also include your data applications. The detailed description of the feature and some config examples are found at
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cg/hqos_c/part50/hautoq2.htm
Hope this helps! PLease rate all posts.
Regards, Martin
