ingress to egress port move packets regardless of vlanids
merrittr
Hello I have a situation where packets of mayn types will be comming in with or with out vlanids on a 10gbe port (the ones with vlanids coule be anywhare from 0-4095)
what i need to do it take then from 10gbe port X and send them out Port Y untouched the packets themselves will be ethernet  other thank that i cannot guarantee what format they will take is this possible?
eduardopozo56
For this scenario, you should use QinQ tunneling:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/12-2SX/configuration/guide/book/dot1qtnl.html
This feature allows to receive all packets on an access vlan (tagged and untagged) and re-encapsulate them inside another vlan packet.
You have to check if your Switch/Linecard supports this feature and be carefull with the native vlans (client sent untagged by default)
eduardopozo56
