insufficient processor memory
krutibasa majhi
I have a cisco 7206 VXR with c7200-adventerprisek9-mz.124-24.T8.bin ios. Most of the time i am not able to login through my tacacs password .After reboot, the router acts as normal and again after a few hours same thing happens . pls find the log details .If any body knows the solution please share .
thank u
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
You might have some configuration issue that consumes RAM over time (e.g. a static route pointing to an interface w/o a next hop IP) or a memory leak due to some IOS bug.  The former is corrected by avoiding that configuration (or obtaining more RAM), the latter often by upgrading your IOS.
Vinit Jain
There is possibly something that might be eating up the memory over time.
You can check for memory leak using the below command:
- show memory debug leak chunk
This can help understand which process is having a memory leak. Be cautious when you are running this command, this can cause high CPU on the router.
--Vinit
