Inter/Intra vlan ACL- OSPF
mvsheik123
Level 7
Level 7
Hello experts,
Core: DC  : 2- 6500 (PO Trunked) Configured L3 vlan interrfaces with HSRP.
Vlans:
Servers - 192.168.5.0/24
PCs: 192.168.10.0/24
Phones : 192.168.20.0/24
Replica-exchange: 192.168.30.0/24
DR- One Core SW:
Vlans:
Servers vlan - 10.10.5.0/24
PCs: 10.10.10.0/24
Phones : 10.10.20.0/24
Replica-exchange: 10.10.30.0/24
OSPF is the routing protocol. Everything works fine.
New requirement (exchange 2010 MAPI & DAG subnets)
192.168.5.0 <--> 192.168.30.0 & 10.10.30.0 : Communication should fail
10.10.5.0/24<--> 192.168.30.0 & 10.10.30.0 : Fail
Replica@DC <--> Replica@DC: work
Replicas --> Rest of the nw- not that of an issue.
Iam thinking of adding a Extended ACLs on Replica-Exchange (DC & DR) and servers Vlan interfaces to block bidirectional communication.
CORE1 &2:
access-list 101 deny ip 192.168.5.0 0.0.0.255 192.168.30.0 0.0.0.255
access-list 101 deny ip 10.10.5.0 0.0.0.255 192.168.30.0 0.0.0.255
access-list 101 permit ip any any
access-list 102 deny ip 192.168.30.0 0.0.0.255 192.168.5.0 0.0.0.255
access-list 102 deny ip 192.168.30.0 0.0.0.255 10.10.5.0 0.0.0.255
access-list 102 permit ip any any
int vla30
desc: Replication
ip access-group 101 in
ip access-group 102 out
Similar to the same on DR as well.
I wanted to see if ACL is the way to go or any other suggested methods with OSPF being the routing protocol.
Thanks in advance
MS
Marwan ALshawi
I think ACL is a good choice because any route filtering will lead to issues of blocking communications between other subnets that you might need it
ACL is a simple solution for your requirement
Always keep it simple
Hope this help
Marwan ALshawi
Hope this help
mvsheik123
Level 7
Level 7
Perfect. Thank you.
