How I can see what features does IOS support?
webstd.design
How I can see what features does IOS support? I can do this with SDM. How I can do this by console/remote access?
Peter Paluch
The complete list of features supported by a particular IOS can be found using the Feature Navigator online tool at:
http://cisco.com/go/fn
There, click on the 'Search by Image' link and in the form, paste the entire IOS image name in the respective input line, then click 'Continue'.
Best regards,
Peter
Dear peter ,,
i tried this tool but it not work for this ios
c3560-ipservicesk9-mz.150-1.SE1.bin
do you know if its working with certain ios types !!!
Best Regards
Ossamy
Response on anohter post.
1. select IOS
2. select cat3550 in the platform window
3. take the.bin off the image name.
Ossamyasked this question in another thread in this forum and I suggest that discussion focus on that thread.
Here is a link to that thread:
https://supportforums.cisco.com/thread/2120755?tstart=0
And it looks to me that the image name that he gives is not a valid image name.
Rick
Rick
