Inter-VLAN routing between VLAN interfaces in different VRFs
tim-armstrong
I am trying to allow clients in vrf 'I' and vrf 'V' to access a NTP server in vrf 'NTP'.  With my current configuration this is not working.  For example, and likewise for all other clients, 'VRF-I-Client-1' (10.1.31.100) can ping the SVI for VLAN 50 in vrf NTP (10.3.50.254), but CANNOT ping the 'NTP-Server' within that same subnet (10.3.50.201).
Interestingly enough, i can ping the ntp-server from the switch using the vrf I routing table when sourcing the ping from vlan31, but can't ping from a client attached to vlan31.  Is this normal behavior? Ping results shown below.
Question:  How can I modify configuration (or concept) to allow for all clients in vrf I and vrf V to access the NTP-server?   Is this normal behavior of my configuration, or is this a GNS3 issue or IOS/IOU issue?
I have included the ping results, routing tables for each vrf, and the running config.  I have implemented vrf-lite with import/export statements in the vrf definitions to share routes and am using BGP to redistribute connected.
VLAN/VRFs
VLAN 50 SVI is associated with vrf NTP (10.3.50.254)
VLAN 31 SVI is associated with vrf I (10.1.31.254)
VLAN 32 SVI is associated with vrf V (10.1.32.254)
endpoints:
NTP Server - 10.3.50.201 /24
VRF-I-client 1 - 10.1.31.100
VRF-I-client 2 - 10.1.31.101
VRF-V-client 1 - 10.1.32.100
VRF-V-client 1 - 10.1.32.101
GNS3 environment:
GNS3 version:  2.1.21
GNS3 running on Ubuntu Linux
This example GNS3 architecture is a simplified mock-up of a larger environment i have to focus on a single issue with Inter-vlan routing between vlans on different VRFs.
ping results:
ping NTP-Serverfrom L3-Switch source vlan31 (Success)
L3-Switch#ping vrf I 10.3.50.201 source vlan31
Sending 5, 100-byte ICMP Echos to 10.3.50.201, timeout is 2 seconds:
Packet sent with a source address of 10.1.31.254
ping NTP-Server from L3-Switch source vlan32 (Success)
L3-Switch#ping vrf V 10.3.50.201 source vlan32
Packet sent with a source address of 10.1.32.254
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/2 ms
ping NTP-Server from VRF-I-Client-1 (Success)
VPCS> ping 10.3.50.254
84 bytes from 10.3.50.254 icmp_seq=1 ttl=255 time=0.395 ms
84 bytes from 10.3.50.254 icmp_seq=2 ttl=255 time=0.540 ms
ping NTP-Server from VRF-I-Client-1 (FAIL)
VPCS> ping 10.3.50.201
10.3.50.201 icmp_seq=1 timeout
10.3.50.201 icmp_seq=2 timeout
L3-Switch##show ip route vrf NTP
Routing Table: NTP
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
Gateway of last resort is not set
     10.0.0.0/8 is variably subnetted, 6 subnets, 2 masks
B        10.1.31.0/24 is directly connected, 07:08:00, Vlan31
L        10.1.31.254/32 is directly connected, Vlan31
B        10.1.32.0/24 is directly connected, 07:00:53, Vlan32
L        10.1.32.254/32 is directly connected, Vlan32
C        10.3.50.0/24 is directly connected, Vlan50
L        10.3.50.254/32 is directly connected, Vlan50
L3-Switch#show ip route vrf I
Routing Table: I
      10.0.0.0/8 is variably subnetted, 4 subnets, 2 masks
C        10.1.31.0/24 is directly connected, Vlan31
B        10.3.50.0/24 is directly connected, 07:08:32, Vlan50
L3-Switch#show ip route vrf V
Routing Table: V
C        10.1.32.0/24 is directly connected, Vlan32
B        10.3.50.0/24 is directly connected, 07:09:28, Vlan50
Running Config L3-Switch
vrf definition I
description Virtual Router I
rd 65000:11
address-family ipv4
 route-target export 6500:11
 route-target import 6500:50
exit-address-family
vrf definition NTP
description Virtual Router NTP to all devices
rd 65000:50
address-family ipv4
 route-target export 6500:50
 route-target import 6500:11
 route-target import 6500:12
exit-address-family
vrf definition V
description Virtual Router V
rd 65000:12
address-family ipv4
 route-target export 6500:12
exit-address-family
no aaa new-model
clock timezone EST -5 0
vtp domain sitex
vtp mode transparent
udld aggressive
no ip icmp rate-limit unreachable
no ip domain-lookup
ip domain-name sitex.af.mil
ip cef
no ipv6 cef
authentication mac-move permit
spanning-tree mode rapid-pvst
spanning-tree loopguard default
vlan internal allocation policy ascending
vlan 31
name A1-I
vlan 32
name A1-V
vlan 50
name NTP
vlan 99
name PARKING
vlan 200
name NATIVE
no cdp run
ip tcp synwait-time 5
class-map match-any non-client-nrt-class
policy-map port_child_policy
class non-client-nrt-class
interface Ethernet0/0
description Link to SW-A1
switchport trunk allowed vlan 31,32,101
switchport trunk native vlan 200
switchport mode trunk
switchport nonegotiate
interface Ethernet0/1
switchport access vlan 99
switchport mode access
switchport port-security mac-address sticky
shutdown
no cdp enable
spanning-tree portfast edge
spanning-tree bpduguard enable
interface Ethernet0/2
shutdown
no cdp enable
interface Ethernet0/3
shutdown
no cdp enable
interface Ethernet1/0
description NTP-D
switchport access vlan 50
no cdp enable
interface Ethernet1/1
shutdown
no cdp enable
interface Ethernet1/2
shutdown
no cdp enable
interface Ethernet1/3
shutdown
no cdp enable
interface Ethernet2/0
description VRF-I-Client
switchport access vlan 31
no cdp enable
interface Ethernet2/1
description VRF-I-Client-2
no cdp enable
interface Ethernet2/2
shutdown
no cdp enable
interface Ethernet2/3
shutdown
no cdp enable
interface Ethernet3/0
description VRF-V-Client-1
switchport access vlan 32
no cdp enable
interface Ethernet3/1
description VRF-V-Client-2
no cdp enable
interface Ethernet3/2
shutdown
no cdp enable
interface Ethernet3/3
shutdown
no cdp enable
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan31
description A1-I
vrf forwarding I
ip address 10.1.31.254 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
interface Vlan32
description A1-V
vrf forwarding V
ip address 10.1.32.254 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
interface Vlan50
vrf forwarding NTP
ip address 10.3.50.254 255.255.255.0
interface Vlan99
description PARKING
no ip address
shutdown
router bgp 100
bgp log-neighbor-changes
address-family ipv4 vrf I
exit-address-family
address-family ipv4 vrf NTP
exit-address-family
address-family ipv4 vrf V
exit-address-family
ip forward-protocol nd
Giuseppe Larosa
Hello Tim,
your VRF configurations are correct as NTP VRF imports the other two VRF route-target exported RT value(s)  and viceversa the other two are importing RT o VRF NTP and also you have configured MP BGP for all the VRFs.
Verify on all emulated hosts including the VPCS the default gateway settings.
Edit:
also one of the emulated hosts may have a SW firewall running this could explain asymmetry on ping results.
Hope to help
Giuseppe
Giuseppe,
Thanks very much for your response and feel better that you confirmed my import/exports and MP-BGP configurations.  I went to confirm a few things and did find a systemic issue with my config.  I have attached the entire running configuration as I added two new vlans with SVIs that are in the default VRF.  I added interfaces to clients in those two new VLANs (10, 20), thus removing any potential vrf issues from the picture.
After testing, I am having the exact same issue.  From client on vlan 10 (10.3.10.100), I can ping local subnet SVI (10.3.10.254).  I can ping the SVI of vlan 20 (10.3.20.254).  But again I can't ping the client in vlan 20 (10.3.20.100).  Removing the VRF complexity, i still can't ping across vlans from client to client.  Feel like i am missing something simple, but can't place it.
Do you see anything?
Ping results - New tests
L3-Switch#ping 10.3.10.100 source vlan20
Sending 5, 100-byte ICMP Echos to 10.3.10.100, timeout is 2 seconds:
Packet sent with a source address of 10.3.20.254
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
SW-A3-500#ping 10.3.10.100 source vlan20
from VLAN20 Client (10.3.20.100)
VPCS> ping 10.3.10.254
84 bytes from 10.3.10.254 icmp_seq=1 ttl=255 time=1.747 ms
84 bytes from 10.3.10.254 icmp_seq=2 ttl=255 time=0.697 ms
# this still not working...
VPCS> ping 10.3.10.100
10.3.10.100 icmp_seq=1 timeout
10.3.10.100 icmp_seq=2 timeout
RUNNING CONFIG
! Last configuration change at 09:17:29 EST Fri Aug 2 2019
version 15.2
service compress-config
hostname L3-Switch
boot-start-marker
boot-end-marker
vrf definition I
rd 65000:11
address-family ipv4
exit-address-family
vrf definition NTP
rd 65000:50
address-family ipv4
exit-address-family
vrf definition V
rd 65000:12
address-family ipv4
exit-address-family
logging discriminator EXCESS severity drops 6 msg-body drops EXCESSCOLL
logging buffered 50000
logging console discriminator EXCESS
no aaa new-model
vtp domain sitex
udld aggressive
no ip domain-lookup
ip cef
no ipv6 cef
vlan 10
name test-default
vlan 20
name test-default20
vlan 21
name A2-I
vlan 31
name A1-I
vlan 32
name A1-V
vlan 50
name NTP
vlan 99
name PARKING
vlan 200
name NATIVE
no cdp run
description Link to SW-A1-904
shutdown
no cdp enable
shutdown
duplex auto
no cdp enable
shutdown
duplex auto
no cdp enable
description NTP-D
no cdp enable
shutdown
no cdp enable
shutdown
no cdp enable
shutdown
no cdp enable
no cdp enable
no cdp enable
switchport access vlan 21
switchport port-security mac-address sticky 0050.7966.6805
no cdp enable
no cdp enable
no cdp enable
no cdp enable
description default-vrf-vlan10
switchport access vlan 10
switchport port-security mac-address sticky 0050.7966.6807
no cdp enable
description default-vrf-vlan20
switchport access vlan 20
switchport port-security mac-address sticky 0050.7966.6806
no cdp enable
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan10
ip address 10.3.10.254 255.255.255.0
interface Vlan20
ip address 10.3.20.254 255.255.255.0
interface Vlan21
vrf forwarding I
ip address 10.2.21.254 255.255.255.0
interface Vlan31
description A1-I
vrf forwarding I
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
interface Vlan32
description A1-V
vrf forwarding V
no ip redirects
no ip unreachables
no ip proxy-arp
ip pim sparse-dense-mode
no ip route-cache
interface Vlan50
vrf forwarding NTP
interface Vlan99
description PARKING
no ip address
shutdown
router bgp 100
exit-address-family
exit-address-family
exit-address-family
no ip http server
ip http authentication local
no ip http secure-server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
Tim
Running config.
Hello Tim,
again your multilayer switch configuration is fine and even removing VRFs from the network test you cannot ping client to client in different Vlans.
The possible issues here are on the emulated hosts:
a) check if every emulated host has the appropriate default gateway = SVI IP address on same Vlan
b) check if emulated hosts have any form of SW firewall enabled that may prevent sending back ICMP echo reply. If emulated hosts are windows based check the windows firewall settings, if they are linux based check iptables.
Hope to help
Giuseppe
