inter-vlan routing cisco 1921
mmartinez
I setup this Cisco 1921 with three vlans; vlan2, vlan3, vlan11 & vlan 3500. Vlan 3500 is my management vlan and I am currently not able to ping or access any of the management devices. The switch where all of the devices are connected has the uplink port tagged with the same vlans and the ports have the correct settings for its particular vlan configuration. What am I missing??? Here is part of the config:
version 15.1
hostname RT1
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone EST -5 0
clock summer-time EDT recurring
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 192.168.1.120 192.168.1.140
ip dhcp excluded-address 10.10.10.2 10.10.10.10
ip dhcp excluded-address 192.168.2.1 192.168.2.10
ip dhcp excluded-address 192.168.1.98 192.168.1.100
ip dhcp pool OPERATIONS
 network 192.168.1.0 255.255.255.0
 domain-name OPs
 default-router 192.168.1.254
 dns-server 8.8.8.8 8.8.4.4
ip dhcp pool OPERATIONS2
 network 192.168.2.0 255.255.255.0
 domain-name OPsPhones
 default-router 192.168.2.1
ip dhcp pool WIFI
 network 10.170.1.0 255.255.255.0
 domain-name Wifi
 default-router 10.170.1.1
ip dhcp pool MGMT
 network 10.10.10.0 255.255.255.0
 domain-name MGMT
 default-router 10.10.10.1
redundancy
class-map match-any WebEmail
 match protocol http
 match protocol secure-http
 match protocol ftp
 match protocol smtp
 match protocol pop3
class-map match-any Voip
 match protocol sip
 match protocol skype
policy-map QoSPolicy
 class Voip
  set dscp ef
  priority percent 70
 class WebEmail
  bandwidth remaining percent 30
 class class-default
  fair-queue
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description Fiber
 ip address 100.100.100.200 255.255.255.240
 ip nbar protocol-discovery
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
 service-policy output QoSPolicy
interface GigabitEthernet0/1
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/1.2
 description [0/1.2] OPERATIONS
 encapsulation dot1Q 2
 ip address 192.168.1.254 255.255.255.0
 ip nat inside
interface GigabitEthernet0/1.3
 description [0/1.3] Operations2
 encapsulation dot1Q 3
 ip address 192.168.2.1 255.255.255.0
 ip nat inside
interface GigabitEthernet0/1.11
 description [0/1.11] WIFI
 encapsulation dot1Q 11
 ip address 10.170.1.1 255.255.255.0
 ip nat inside
interface GigabitEthernet0/1.3500
 description [0/1.3500] MGMT
 encapsulation dot1Q 3500
 ip address 10.10.10.1 255.255.255.0
 ip nat inside
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip route 0.0.0.0 0.0.0.0 100.100.100.199
ip access-list extended dvr
 permit tcp any any range 8000 8001
 permit tcp any any eq 7000
 permit tcp any any range 8000 8002
 permit tcp any any range 9010 9012
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
access-list 100 permit ip 192.168.2.0 0.0.0.255 any
access-list 100 permit ip 10.10.10.0 0.0.0.255 any
access-list 100 permit ip 10.170.1.0 0.0.0.255 any
route-map ACL-ACCESS permit 10
 match ip address 100
Richard Burts
I have looked through the part of the config that you posted and do not see any particular issues that would impact access for the management vlan. I do see some things such as route-map ACL-ACCESS and ip access-list extended dvr which are not used in the part of the config that you posted and it makes me wonder what else is in the config that you have not shown us.
As a starting point in investigating the issue I would suggest that you post the output of show arp (or show ip arp) from the 1921. It will show us some things about what can be accessed. In particular I would like to see whether the router has learned any arp entries in vlan 3500.
I would suggest that we should consider the possibility that the issue is not with the 1921 but with the switches to which it connects. What can you tell us about those switches? Is vlan 3500 a valid vlan on the switch to which the 1921 connects? Can you post the output of these commands from that switch
show vlan
show interface trunk
Rick
Rick
