Inter VLAN routing using cisco 881 and Layer2 swiich with ispsimrouter
saad123
I have a CISCO 881 router connected with Layer 2 switch also ISP SIM router for internet is connected with Layer 2 switch
Layer 2 switch having 2 vlans -
Vlan 1
vlan 50
want vlan to communicate with each other and also have interent access on both the vlans
i am able to do intervlan - both are able to communicate but there is not internet on VLANS do i need to NAT as well ???
Please advise
Richard Burts
Assuming that you are using Private IP addressing for your inside networks then yes you do need NAT for them to get access to Internet.
Rick
