Showing results forĀ
Search instead forĀ
Did you mean:Ā
Inter VRF Route Export Map Problem
Andrew Powell
I am trying to export a route between one VRF and another in a BGP MPLS environment using a route map and prefix list. Both the source and target VRFs exist on the same device, a 6513 running IOS 12.2(33)SXJ7
As a test I originally had static routes in my routing table for the routes I wanted to export, and it worked perfectly, However when I implemented it live with BGP routes instead of static, the export would not work it is as if the prefix list couldn't match the same route when it was learned via BGP rather than static
Here is the relevant sections of config:
ip prefix-list TEST seq 5 permit 10.1.1.1/32
route-map VRFA-EXPORT permit 10
match ip address prefix-list TEST
set extcommunity rt  65001:200 additive
ip vrf VRF-A
rd 1.1.0.251:2670
export map VRFA-EXPORT
route-target export 51551:2670
route-target import 51551:2670
ip vrf VRF-B
rd 65001:200
route-target export 65001:200
route-target import 65001:200
The routing table for VRF-A looks like this:
Gateway of last resort is 10.0.0.6 to network 0.0.0.0
     10.0.0.0/32 is subnetted, 4 subnets
B       10.2.1.1 [200/0] via 30.30.30.30, 00:34:46
B       10.1.1.2 [200/0] via 20.20.20.20, 00:34:46
B       10.1.1.3 [200/0] via 20.20.20.20, 00:34:46
B       10.1.1.1 [200/0] via 20.20.20.20, 00:32:00
B*   0.0.0.0/0 [20/0] via 10.0.0.6 (VRF-B), 00:34:46
and a sho bgp vpnv4 unicast vrf VRFA 10.1.1.1/32 looks like this.
R2#sh bgp vpnv4 unicast vrf VRF-A 10.1.1.1/32
BGP routing table entry for 1.1.0.251:2670:10.1.1.1/32, version 8
Paths: (1 available, best #1, table VRF-A)
Not advertised to any peer
Local, imported path from 20.20.20.20:2670:10.1.1.1/32
20.20.20.20 from 20.20.20.20 (20.20.20.20)
Origin incomplete, metric 0, localpref 100, valid, internal, best
Extended Community: RT:51551:2670
mpls labels in/out nolabel/17
In the above it looks like the full BGP route is actually 1.1.0.251:2670:10.1.1.1/32 which is the route prepended by the RD, could this be why the prefix list isn't matching the route? Strange as it appears correctly as 10.1.1.1 in the routing table
info
Remove and attach the route map
CCNA Training in Bangalore
