Interconnect a router 1941 to fiber optic media converter
jeannzonzidi1
I has a 1841 router connected in media converter rj45-optical fiber; the interfaces fastethernet have any errors :
FastEthernet0/0 is up, line protocol is up
Hardware is Gt96k FE, address is 9caf.ca71.9fb4 (bia 9caf.ca71.9fb4)
Description: LAN
Internet address is 172.16.243.42/30
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
reliability 255/255, txload 1/255, rxload 2/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:08, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 839000 bits/sec, 76 packets/sec
5 minute output rate 23000 bits/sec, 42 packets/sec
16427382 packets input, 1627663670 bytes
Received 10604 broadcasts, 1097 runts, 0 giants, 0 throttles
106049 input errors, 106037 CRC, 0 frame, 6 overrun, 0 ignored
0 watchdog
9315298 packets output, 641397886 bytes, 0 underruns
0 output errors, 0 collisions, 6 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier
FastEthernet0/1 is up, line protocol is up
Hardware is Gt96k FE, address is 9caf.ca71.9fb5 (bia 9caf.ca71.9fb5)
Description: WAN (10.140.0.14)
Internet address is 10.140.0.14/16
reliability 255/255, txload 2/255, rxload 1/255
Last input 00:00:00, output 00:00:00, output hang never
5 minute input rate 42000 bits/sec, 45 packets/sec
5 minute output rate 870000 bits/sec, 77 packets/sec
9314397 packets input, 1125438776 bytes
Received 16332 broadcasts, 58 runts, 0 giants, 0 throttles
1344 input errors, 1342 CRC, 0 frame, 1 overrun, 0 ignored
0 watchdog
16467493 packets output, 2495255891 bytes, 0 underruns
5471 unknown protocol drops
i has changed the cable crossover in media converter, nothing change.
I want to change the router for a cisco 1941;
Help me, the router cisco 1941 can support to optical fiber link with 100 Mbps ?
saif musa
Level 4
Level 4
Cisco router 1941 can support up to 1Gbps, also you trying to upgrade your router to the same router series so there is nothing to worry about.
Hope that helps
