internal devices are unable to communicate with outside network
jameharmon
I hope someone here can help me. I have setup a cisco router 2911 to study for canna, and I am unable in any for or fashion to get anything to communicate out.
Can someone please give me some advice?
Current configuration : 4174 bytes
! Last configuration change at 21:47:24 UTC Mon Jan 22 2018 by semi
version 15.4
hostname cishome
boot-start-marker
boot system flash c2900-universalk9-mz.SPA.154-2.T1.bin
boot-end-marker
enable secret 5 __________.
enable password_________
aaa new-model
aaa authentication login default local
aaa session-id common
no ip routing
ip dhcp excluded-address 10.0.100.1 10.0.100.30
ip dhcp pool MAIN
 network 10.0.100.0 255.255.255.0
 default-router 10.0.100.1
 dns-server 84.200.------ 84.200.--------
 domain-name ----------------
 lease 7
no ip cef
no ipv6 cef
crypto pki trustpoint TP-
crypto pki certificate chain TP-A800CC D450AB15 593D495E
  quit
license udi pid CISCO2911/K9 sn FTX1503AL35
username semi privilege 15 secret 5 $1$IKdz$c1GdjEOAUV6ZupnSyjulG/
redundancy
ip ssh version 2
interface Embedded-Service-Engine0/0
 no ip address
 no ip route-cache
 shutdown
interface GigabitEthernet0/0
 ip address dhcp
 ip nat outside
 ip virtual-reassembly in
 no ip route-cache
 duplex auto
 speed auto
interface GigabitEthernet0/1
 ip address 10.0.100.1 255.255.255.0
 ip nat inside
 no ip route-cache
 duplex auto
 speed auto
 no mop enabled
interface GigabitEthernet0/2
 no ip address
 no ip route-cache
 shutdown
 duplex auto
 speed auto
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip nat inside source list 10 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 10.0.1.1
ip access-list extended allowedservices
 permit tcp any any eq www
 permit tcp any any eq 443
 permit tcp any any eq 445
 permit tcp any any eq 143
 permit tcp any any eq pop3
 permit tcp any any eq 997
 permit tcp any any eq 995
 permit tcp any any eq smtp
 permit tcp any any eq telnet
 permit tcp any any eq 22
 permit tcp any any eq domain
 permit udp any any eq domain
 permit icmp any any echo-reply
 permit tcp any any eq 3389
 permit tcp any any eq 69
snmp-server community public RO
control-plane
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0
 exec-timeout 40 0
 password Blackbox47$
 transport input ssh
line vty 1 4
 exec-timeout 5 0
 transport input ssh
scheduler allocate 20000 1000
end
cishome#
2 Accepted Solutions
Hi, You've got the following defined "ip nat inside source list 10 interface GigabitEthernet0/0 overload", where "10" would be the standard ACL listing all of the internal subnets, but I don't see the output of this in the config you supplied. Do you have that ACL defined? If not, that could be the issue.
I assume this router behind another ISP router? which is why the default route next hop is 10.0.1.1 and not a public IP address.
You haven't got that ACL applied anywhere (not that I can see), so it won't be doing anything yet. You'd want to apply it to the Gi0/1 interface.
 ip access-group allowedservices in
\\ To confirm the ACL is working, make sure there are hits
show ip access-list
Thanks for the help only other issue im having now is that I can view ever webpage, just some I assume its because of my extended access-list
show ip access-list
thanks I appreciate the help, and yes I wasn't going to move away from the router until I knew it worked. Thanks a bunch, that was dumb on my part.
