Internal DNS, NAT & Firewall Issue (I think)
CSCO10174474
Hi Guys,
I've been struggling with this one for a few days now - I'm sure its something simply that I've overlooked but for the life of me I can't see it, so I'm hoping a fresh set of eyes might do the trick.
Situation
     Cisco 887W Router (IOS v15)
     Static IP on External Interface - Dialer0
     Several Security Zones set up on Internat Interfaces
     Cisco Zone-Based-Firewall in operation
     Nat in operation
     Internal DNS Server (DMZ) being served to External Clients
     Internal WWW Server (DMZ) being served to External Clients
Issue
     Everything is working perfectly - Firewall, NAT, Internal DNS, etc, EXCEPT when quering the DNS Server from outside the Network a "Timeout waiting for response" message is received (via the Trace DNS Delegation website at www.simpledns.com/lookup-dg.aspx).
Relevant Config Entries
ip nat inside source static tcp 192.168.1.2 53 interface Dialer0 53
ip nat inside source static udp 192.168.1.2 53 interface Dialer0 53
zone security OUTSIDE
zone security DMZ
zone-pair security OUTSIDE_TO_DMZ source OUTSIDE destination DMZ
     service-policy type inspect POLICYMAP_ACCESS_TO_DMZ_SERVERS
policy-map type inspect POLICYMAP_ACCESS_TO_DMZ_SERVERS
     class type inspect CLASSMAP_ACCESS_TO_DMZ_SERVERS
          inspect
     class class-default
          drop
class-map type inspect match-all CLASSMAP_ACCESS_TO_DMZ_SERVERS
     match access-group name ACCESS_TO_DNS_SERVERS
ip access-list extended ACCESS_TO_DNS_SERVERS
     permit udp any host 192.168.1.2 eq domain
     permit tcp any host 192.168.1.2 eq domain
Any help greatly appeciated - thanks
6 Replies 6
cadet alain
Your config is correct, does the DNS server have a correct route back ?
Alain
Hello
Try using Match-Any statement instead of a Match-All for the ZBFW class map related to you extended ACL.
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
Hi Paul,
there is only 1 match statement so match-all or match-any will do the same.
Alain
Hello
Yes you are correct - Apologies I was thinking of the acl and looking the class-map should have been just the class-map only.
CSCO10174474
Just for bevrevity can you clear you zone counters and test again and show the output from the zone policy
clear zone-pair counter
sh policy-map type inspect zone-pair sessions
res
Paul
Thanks.
Kind Regards
Paul
Hi Paul,
Relevant Zone Policy Output Below:
policy exists on zp OUTSIDE_TO_DMZ
     Zone-pair: OUTSIDE_TO_DMZ
          Service-policy inspect : POLICYMAP_ACCESS_TO_DMZ_SERVERS
               Class-map: CLASSMAP_ACCESS_TO_DMZ_SERVERS (match-all)
                    Match: access-group name ACCESS_TO_DNS_SERVERS
          Inspect
               Class-map: class-default (match-any)
                    Match: any
                    Drop
                         0 packets, 0 bytes
On a further note, we know the Access-List is matching because we can see its Match-Count go up.
So, the plot thickens - thanks guys
You didn't reply to my request? Are you sure the DNS server has got the correct route to reply ?
Can you sniff on the DNS server and use the packet capture feature on the router to capture on both interfaces and post us all these pcap files.
Alain
