Internet access by multiple VLAN
Arup Dutta
Hi All,
        I have 14 vlan for different subnet,between them connectivity is going fine but i want all VLN's member use internet access facility.
i configured router but router goes restert every 5 to 10 minute.
plese help me. i am attached my network diagram and router configure
Thnx,
Arup
Peter Paluch
Hello Arup,
Router restarting itself is definitely something very unpleasant and in most cases, it is caused by an IOS bug or possible hardware problem. In any case, if a router reboots itself, it may log a console message why it crashed, and also, the show version command output should contain a brief explanation of the reason for the recent reload. Can you please capture the console during the crash and the subsequent show version output and post it here? Your current configuration does not seem to have any obvious problems, and besides, no configuration should be accountable for router reboots.
Best regards,
Peter
Hi Peter,
thnx for your reply.According to router log i did find NAT
aggregation 99%.
have another way to reach internet to my all VLANs
Arup
On Tue, Nov 16, 2010 at 3:59 PM, paluchpeter <
