Internet ACL not allowing http
Ricky S
Level 3
Level 3
Hi everyone, can you tell me why this ACL, when applied inbound to my outside interface, kills the outbound http traffic?
ip access-list extended internet_block
permit udp any eq bootps any eq bootpc
remark rfc1918 antispoofing
deny   ip host 255.255.255.255 any log
deny   ip 127.0.0.0 0.255.255.255 any log
deny   ip 10.0.0.0 0.255.255.255 any log
deny   ip 172.16.0.0 0.15.255.255 any log
deny   ip 192.168.0.0 0.0.255.255 any log
deny   ip any 10.0.0.0 0.255.255.255 log
deny   ip any 172.16.0.0 0.15.255.255 log
deny   ip any 192.168.0.0 0.0.255.255 log
remark gre tunnels permitted
permit udp any any eq isakmp
permit esp any any
permit gre any any
permit udp any any eq non500-isakmp
permit tcp any any eq www established
permit tcp any any eq 443 established
remark allow ping and traceroute responses
permit icmp any any traceroute
permit icmp any any echo-reply
deny   icmp any any redirect
deny   ip any any
interface gigabitethernet0/0
ip access-group internet_block in
strange if it was hit or miss , i tried it with success and all hits.
What you can do is on your 190 line do deny   ip any any log ( make sure you have syslog enabled ) and then open yahoo.com in browser and see what error you see on syslog, and why packet is denied.
by the way how we do is simply tcp any any established and never faced any issues. never tried establushed for 80 in my network so far. but did just for a test.
8 Replies 8
Giuseppe Larosa
Hello Ricky,
if you mean web servers that are on the internet you should have used
permit tcp any eq www any established
permit tcp any eq 443 any  established
the ACL is applied inbound on internet facing interface so you  have to see the well known ports on the source part not the destination part
the lines you have used refers to http or https sessions with servers that are inside your network
Hope to help
Giuseppe
ahmad82pkn
Level 3
Level 3
what you need to do is in your ACL
permit tcp any eq 80 any
Hi Ahmad, thanks.
Shouldn't the "established" keyword be added for security? I am not comfortable leaving port 80 open for all incoming traffic unless it was initiated from the inside.
hum, then do this
permit tcp any eq 80 any established
since source ports is 80 and 443 when reply is coming back from web server.
Ok with the established keyword it sporadic, a hit or a miss. I was able to go to google.com but was not able to go to yahoo.com etc. Is there any other ways I can block port 80 and 443 unless traffic is return traffic to a request intiated from the inside?
Ahh why didn't I think of that about the tcpy any any
I also did tcp any any established and now everything works fine. Issue resolved.
I don't care much about what people from the inside can go to, its more from the outside in.
Thanks a bunch for your help!
Glad to help you
