Quality of service - access-list problem?
Basically, I am having issues with my access-list on a qos policy.  Doing telnet/ssh session through this interface to the router I expect to see marking AF21.  It doesnt though, it marks it AF41.  It is almost as if the policy-map doesnt like matching the protocol, if I remove "permit ip tcp any any eq www" it marks it AF31 - which should only be smtp traffic...it just seems to match the "permit tcp any any" portion and ignore the destination port...
The router is ME3800X and the port is a trunk port and traffic enters/leaves by the same interface - though it makes no difference if i telnet to the router or hosts through the router:
interface GigabitEthernet0/4
  switchport trunk allowed vlan 2-101,104-4094
switchport mode trunk
mtu 2000
speed nonegotiate
no cdp enable
no vtp
spanning-tree bpdufilter enable
service-policy input EFM-IN
service-policy output UPLINKS
policy-map EFM-IN
class CS7
set ip dscp CS7
set mpls exp top 6
class  EF
set ip dscp  EF
set mpls exp top 5
class  AF41
set ip dscp AF41
set mpls exp top 4
class  AF31
set ip dscp  AF31
set mpls exp top 3
class  AF21
set ip dscp  AF21
set mpls exp top 2
class AF11
set ip dscp  AF11
set mpls exp top 1
class class-default
set mpls exp top 0
set ip dscp default
class-map match-any CS7
match access-group name CS7
class-map match-any EF
match access-group name EF
class-map match-any AF11
match access-group name AF11
class-map match-any AF21
match access-group name AF21
class-map match-any AF31
match access-group name AF31
class-map match-any AF41
match access-group name AF41
[greyed out a couple of values]
ip access-list extended CS7
permit ip host xxx.xxx xxx.xxx
ip access-list extended EF
permit ip any xxx.xxx.0.0 0.0.15.2
permit ip any xxx.xxx.6.0 0.0.0.25
permit ip any xxx.xxx.64.0 0.0.63.255
permit ip any xxx.xxx.0.0 0.0.255.255
ip access-list extended AF41
permit tcp any any eq www
ip access-list extended AF31
permit tcp any any eq smtp
ip access-list extended AF21
permit tcp any any eq 22
permit tcp any any eq 23
ip access-list extended AF11
permit tcp any any eq ftp
permit tcp any any eq ftp-data
any ideas greatly appreciated!
Nicholas
Giuseppe Larosa
Hello Nicholas,
according to configuration guide for the ME3600-ME3800 you need a global command to be able to match on layer 4 ports.
In addition to this there is a limitation on a maximum of 8 port matching operation per interface on received traffic
To enable layer 4 port matching on the switch use the
platform qos enable layer4-port-match
command.
see
http://www.cisco.com/en/US/docs/switches/metro/me3600x_3800x/software/release/15.2_2_S/configuration/guide/swqos.html#wp1000748
You may need to review your QoS policy  taking in account the per interface L4 port matching limitation
Hope to help
Giuseppe
Giuseppe Larosa
Hello Nicholas,
command.
see
Hope to help
Giuseppe
Thanks for this, I shouldve read the guide closer.  Still, only 8 layer 4 matches per interface...they need to work on the IOS for this kit I think.
thanks
Nicholas
