Internet cuts off after a while (Cisco 1721)
BHEbrecht
I seem to be having some problems with my 1721. For some reason after a while the internet cuts off and the whole network looses internet. And the only way to get the net back is to restart the cable modem. The time between it cutting off is random, sometimes it takes 12hrs or so and sometimes only like 20min. I took the 1721 out of the connection and used a regular linksys wireless router and everything was fine. The internet didn't cut off at all. Then when I put the 1721 back on, the net cut off again. Anyone have an idea? I tried different IOS's, but didn't work. I can't seem to find the problem. Any suggestions would be great, please!
Thanks in advance!
thisisshanky
Level 11
Level 11
Can you paste your configs. When the internet cuts off, do see cable/internet lights on cable modem lit ? At the same time, are you able to ping to an Internet IP address from the 1721 console ?
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Just after I posted I reset the router to factory settings and reprogrammed it. But the problem still occured about 11hrs later. The cable lights were still on, showing that the cable has a connection but the activity lights weren't flashing so much. They flashed a few times but nothing major to show that there was activity like a download. I was able to ping inside the network, but as far as pinging outside I wasn't able to at all from the 1721. So again I had to restart the cable modem to get a connection back. It's really wierd. Here's my config:
Building configuration...
Current configuration : 3221 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable password
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
crypto pki trustpoint TP-self-signed-345238422
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-345238422
revocation-check none
rsakeypair TP-self-signed-345238422
crypto pki certificate chain TP-self-signed-345238422
certificate self-signed 01
3082023D 308201A6 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 33343532 33383432 32301E17 0D303530 38323830 31353134
355A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3334 35323338
34323230 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
A0113C04 A2BFB1EF 0A7515AD B48CABAB 62A3D071 CFF5FB93 F1A66622 93AFA231
FFF184DB 4C811F5F C5A160DC 538BC53C 13D330ED 4BEC291D A525EF15 84B976D9
0E70FB30 B36E6076 975617A2 D65E6819 C404DF0A 5C8C45C0 97E553BE C2C497BE
060A34EB 82CD0BD6 EDBAF34E D0534197 D818677A CCC7278B 22F01F60 B411C767
02030100 01A36730 65300F06 03551D13 0101FF04 05300301 01FF3012 0603551D
11040B30 09820752 6F757465 722E301F 0603551D 23041830 1680145F 67DC559C
31F48C3A 36179FC7 5450A399 00E50430 1D060355 1D0E0416 04145F67 DC559C31
F48C3A36 179FC754 50A39900 E504300D 06092A86 4886F70D 01010405 00038181
00988B5A 33B99E22 65CC140A 5975D719 5AD882A2 52924278 F446E8AE D858A2F4
DEDA6F3B D1102A1F A1288981 19E02218 19F59DD8 1B663F6B C2C7E3F1 40B551DF
00531B64 D1DD34DC 91F46267 C8D48AE2 0CB97398 769F078F 9F8D16DB 5BF6F9EA
38BBAA36 F5B7ED59 FCB8FE40 75AA4988 39EED9D1 04D5F209 B5C356C2 7F10DCDA B9
quit
username privilege 15 secret 5
interface Ethernet0
ip address dhcp
ip nat outside
ip virtual-reassembly
half-duplex
interface FastEthernet0
ip nat inside
speed auto
ip classless
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
ip nat inside source list 1 interface Ethernet0 overload
access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
banner motd ^C
Authorized access only!
This system is the property of Ebrecht Enterprises.
Disconnect IMMEDIATELY as you are not an authorized user!
Failure to disconnect will result in serious criminal acts,
where you will be prosecuted to the fullest extent of the law.
For authorized access contact:
B Ebrecht
Tel:
E-Mail:
Disconnect IMMEDIATELY if you are not an authorized user!
^C
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
privilege level 15
login local
end
When I read the description of your issue, my first thought was that it might be an issue with the translation. But if you are not able to access the Internet from a session on the router, then it probably is not a NAT issue.
When the problem occurs if you do show arp, do you see the MAC address of the provider device which serves as your default gateway? Can you ping the address of the device which is your defualt gateway>
Rick
Rick
