Internet over Point to Point link
jonnyk123
We have two sites Site A and Site B
Site A has internet and Site B needs to access the internet from site A
I am using OSPF and both sites can see routes to the other site
Site B has the IP address of site A's end of the point to point as the Gateway of last resort however Site B cant access the internet still
When I do show ip route 0.0.0.0 it points towards the ip of site A's end of the point to point
I need to urgently solve this
Thanks in advance for you help
20 Replies 20
Raju Sekharan
Can you do a trace from Site B to any internet address and check where is it getting dropped
Raju
traceroute  209.244.0.3
Tracing the route to 209.244.0.3
VRF info: (vrf in name/id, vrf out name/id)
  1 10.120.20.22 0 msec 9 msec 0 msec
  2  *  *  *
  3  *  *  *
this is the address of Site A's end of the point to point
Hi  Jonny
What is the next device after
10.120.20.22
Raju
John Blakley
What does site A go through to get to the internet? Does it redirect traffic to another device like a firewall or another router? What's site A's gateway of last resort?
HTH, John *** Please rate all useful posts ***
It goes through a firewall and Site A's gateway of last resort the IP of the firewall.
The next device after 10.120.20.22 is the core switch.
Your firewall needs a route back to site B. Does it have that? If not, you'll want to create a route on it pointing to it's next hop internally..possibly switch?
HTH,
John
**** Please rate all useful posts ****
Site B core switch is conncted to switch 10.120.20.22 which is in site A and is then connected to the core switch in site A. The firewall is also connected to 10.120.20.22. Would I put the next hop as core switch or 10.120.20.22 ?
Yes. Put your route pointing to site b and the next hop as the .22 address. If your core knows how to get to site b, you should be good to go.
John
1. Check if your Firewall has route back to Site B
2. Check if FW is configured to Allow the Site B IPs and configured to NAT those IP Addresses
Raju
ALIAOF_
Level 6
Level 6
It would be best if you can post a diagram of your network with IP's and connections.
jonnyk123
I can ping IPs on site B from the core switch and firewall on Site A
The firewall does not have any restrictions to stop Internet access from any range
Is your firewall natting? Do you have the range that site B hosts listed in the firewall to be natted? What type of firewall is it? Since you can ping from the firewall to site B, it's not a routing issue...
HTH,
John
jonnyk123
