internet router configuration
shibindong
we are going to configure the router running BGP with ISP for Internet connection, what is the best practrise to condifure that router in terms of security?
mvsheik123
Level 7
Level 7
There are several points you needs to consider based on your scenario, but see the attached general practices for tightening up the edge routers.
hth
Thank you
MS
joseph.derrick
First and foremost, perimeter devices should be configured with out-of-the box security. Confgure your switch/router with the following:
Block/deny traffic originating from external network using these addresses 10.0.0.0/8, 127.0.0.0, 172.16.0.0/and 192.168.0.0 towards your perimeter devices.
With regards to BGP, routes that should not be advertised nor accepted should be filtered. This is done by configuring filter-lists.
k0rg
