Internet slow performance
thiru.vel10
492905 packets output, 178423745 bytes, 0 underruns
9107 output errors, 22454 collisions, 0 interface resets
Hi thiru,
As paolo said, You should use full-duplex. I still see Half-duplex in your show interface command so I'm not surprised at all why collision errors keep increasing.
CRC should be a layer1-problem to me. If it keep increasing then you should replace the cable for testing. If the problem still occur I'd request ISP to get involved in.
Hopes this helps
Thot
8 Replies 8
paolo bevilacqua
The connected device is set for full-duplex and this one to half. Change setting into or another so that they match.
Duplex settings changed but no luck . Still same status.
Seem strange, for example once full duplex on cisco, it would never show any collision.
F0/1 is directly connected to internet modem. In modem they are setting half duplex. So we have configured the same in our f0/1 interface. I am trying to ping the ISP gate way form r1 is success rate is 100 percent (5/5), round-trip min/avg/max = 4/4/4 ms. My users are facing slow performance issue while accessing the internet application.
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
reliability 253/255, txload 8/255, rxload 14/255
Keepalive set (10 sec)
Half-duplex, 10Mb/s, 100BaseTX/FX
Last input 00:00:01, output 00:00:00, output hang never
Last clearing of "show interface" counters 00:59:45
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 569000 bits/sec, 115 packets/sec
5 minute output rate 349000 bits/sec, 125 packets/sec
263398 packets input, 151321672 bytes
Received 116 broadcasts, 3 runts, 0 giants, 0 throttles
88 input errors, 84 CRC, 0 frame, 0 overrun, 1 ignored
0 watchdog
259264 packets output, 83943118 bytes, 0 underruns
3587 output errors, 14189 collisions, 3 interface resets
0 babbles, 3587 late collision, 0 deferred
0 lost carrier, 0 no carrier
Slow performance ? You're doing 570 kbos download and 350 upload, that is not little for broadband access. Check if you have concurrent P2P or video downloads users.
Admittedly the output errors ratio is a bit high, and some input errors. Check cabling and possibly replace it. A better choice, put a DSL interface directly into the router to solve any issue.
I have checked the Bandwidth in and out Utilization but it seems not that much. There is no user now but still I am getting the same error in internet interface.
Hi thiru,
Hopes this helps
Thot
Thanks I have reported this issue with ISP. There are working on this issue. For your information I have replace the cable also. I am suspecting problem with ISP.
