Internet Stops randomly for users ISR4331 PPPOE
prash723
After random time (1-2 Days) internet access stops for Lan users. After doing shut - no shut for dialer 1 interface it starts working normally. Can anybody please help
Below are the PPPOE configuration
interface GigabitEthernet0/0/0
description Etisalat-Event-DSL-Link
no ip address
negotiation auto
pppoe enable group global
no cdp enable
pppoe-client dial-pool-number 1
end
interface Dialer1
ip address negotiated
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap chap callin
ppp chap hostname royal103
ppp chap password 7 094A5908115707025F
ppp pap sent-username royal103 password 7 15141C0D0C783B347C
ppp ipcp dns request accept
ppp ipcp route default
ppp ipcp address accept
no ip virtual-reassembly
end
When internet stops for user we can ping google.com from router CLI.
Logs are attached in file (at the time when internet was stopped).
14 Replies 14
post the full running configuration (sh run) of your router.
Thanks for the response. I have attached the show run
try and take all the IPCP stuff out and use a default route instead. Also, add the MTU settings to the dialer interface:
interface Dialer1
--> ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
--> ip route 0.0.0.0 0.0.0.0 Dialer 1
Thanks for the suggestion.
MTU is already 1492 (doesn't shows in show run in version 16.6)
I will remove ipcp from dialer interface and add default route.
Lets test if this resolves the problem.
what else is in your network ? Your clients are not directly connected to the 4331, but to a device with IP address 192.168.12.2. Might be worth posting the configs of whatever other devices you have in the path from your clients to the 4331...
We made above changes yesterday and monitoring the router now.
Keep us updated...
Hi Georg,
The issue appeared again. Fixed with shut-no shut for dialer interface.
So putting manual default route didn't worked.
Prashant
Hello
Your configuration looks fine however the logging suggests a possible hardware related issue to this linecard, try reseating in into the rtr
Kind Regards
Paul
Thanks for response.
Can you please point out which log suggest hardware related issue also the procedure for "reseating in into the rtr".
Hello
000023: *Nov 9 09:03:41.064 DXB: %SYS-5-CONFIG_I: Configured from memory by console
000024: *Nov 9 09:03:41.082 DXB: %IOSXE_OIR-6-REMSPA: SPA removed from subslot 0/0, interfaces disabled
000025: *Nov 9 09:03:41.088 DXB: %SPA_OIR-6-OFFLINECARD: SPA (ISR4331-3x1GE) offline in subslot 0/0
000026: *Nov 9 09:03:41.093 DXB: %IOSXE_OIR-6-INSCARD: Card (fp) inserted in slot F0
000027: *Nov 9 09:03:41.093 DXB: %IOSXE_OIR-6-ONLINECARD: Card (fp) online in slot F0
000028: *Nov 9 09:03:41.095 DXB: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 0
000029: *Nov 9 09:03:41.095 DXB: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 0
000030: *Nov 9 09:03:41.097 DXB: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 1
000031: *Nov 9 09:03:41.097 DXB: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 1
000032: *Nov 9 09:03:41.110 DXB: %IOSXE_OIR-6-INSSPA: SPA inserted in subslot 0/0
000033: *Nov 9 09:03:42.132 DXB: %LINK-5-CHANGED: Interface GigabitEthernet0, changed state to administratively down
000034: *Nov 9 09:03:42.133 DXB: %IOSXE_RP_ALARM-6-INFO: CLEAR CRITICAL GigabitEthernet0 Physical Port Link Down
000035: *Nov 9 09:03:44.110 DXB: %SYS-5-RESTART: System restarted --
000036: *Nov 9 09:03:44.289 DXB: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, changed state to up
000037: *Nov 9 09:03:44.289 DXB: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
000038: *Nov 9 09:03:45.958 DXB: %SPA_OIR-6-ONLINECARD: SPA (ISR4331-3x1GE) online in subslot 0/0
000039: *Nov 9 09:03:46.836 DXB: %SYS-6-BOOTTIME: Time taken to reboot after reload = 365 seconds
show facility-alarm status
show platform diag
Kind Regards
Paul
Hi Paul,
The issue appeared again, I have attached todays logs with platform Diagnostic Output.
Can you please check.
Prashant
AS I UNDERSTAND YOU ARE CONNECTING THE VDSL MODEM TO G0/0/0 IN BRIDGE MODE
THE LOG SHOWS THAT THE INT G0/0/0 GETS DOWN THEN DIALER GETS DOWN AFTER IT
THAT INDICATES A PROBLEM IN MODEM ITSELF NOT THE ROUTER
CHNGE THE MODEM WITH NEW OR BETTER ONE THAT WILL FIX THE PROBLEM.
Thanks for the sugestion.
I will check for modem from ISP.
