InterVLAN routing on Catalyst 4948
s.lillard
I'm new to the forum so forgive me if this has been addressed. I did a search and did not find the answer.
I want to know if the 4948 supports inter-VLAN routing. All of the online documentation indicates that, with the right software, routing protocols are supported but it doesn't come out and say, "Yes, the 4948 does do inter-VLAN routing."
It is a critical feature requirement in my alternative data center project, so I want to get it right.
You input is appreciated!
ananddiwakar
Hie Shawn,
Yes. 4948 supports inter VLAN routing. It is based on 4500 platform. Please see the below link for different models of 4948
http://www.cisco.com/en/US/products/ps6021/prod_bulletin0900aecd801c59cf.html
And the below link is data sheet
http://www.cisco.com/en/US/products/ps6021/products_data_sheet0900aecd8017a72e.html
ananddiwakar
Hie Shawn,
