InterVLAN Routing
cubus
I have started studying networking recently and I have come across a little problem. I have created two VLANs on an L2 switch and I have followed the instruction as shown in here, apart from the hosts' IP addresses. I've created a simulation in VIRL and used Autonetkit to create connections. I'm unable to ping from one VLAN to the other.
Here is my topology:
Where the iosv-1 is the router on a stick, the iosv-2 is on vlan 10, and iosv-3 is on vlan 20.
And here is the output of iosv-1#show ip route:
Gateway of last resort is not set
      192.168.0.0/32 is subnetted, 1 subnets
C        192.168.0.1 is directly connected, Loopback0
      192.168.10.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.10.0/24 is directly connected, GigabitEthernet0/1.10
L        192.168.10.254/32 is directly connected, GigabitEthernet0/1.10
      192.168.20.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.20.0/24 is directly connected, GigabitEthernet0/1.20
L        192.168.20.254/32 is directly connected, GigabitEthernet0/1.20
Any advice will be appreciated.
Here is the virl configuration file:
<?xml version='1.0' encoding='UTF-8' standalone='yes'?>
<topology xmlns="http://www.cisco.com/VIRL" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" schemaVersion="0.95" xsi:schemaLocation="http://www.cisco.com/VIRL https://raw.github.com/CiscoVIRL/schema/v0.95/virl.xsd">
    <extensions>
        <entry key="management_network" type="String">user</entry>
    </extensions>
    <node location="574,177" type="SIMPLE" subtype="IOSv" name="iosv-1" ipv4="192.168.0.1">
        <extensions>
            <entry key="config" type="string">!
! Last configuration change at 17:23:22 UTC Wed Oct 30 2019 by cisco
version 15.7
hostname iosv-1
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
enable password cisco
no aaa new-model
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no ip domain lookup
ip domain name virl.info
ip cef
ipv6 unicast-routing
ipv6 cef
username cisco privilege 15 secret 5 $1$Guje$2YyAr82Whi1fnJ2YA7mQt/
redundancy
no cdp run
interface Loopback0
 description Loopback
 ip address 192.168.0.1 255.255.255.255
interface GigabitEthernet0/0
 description OOB Management
 vrf forwarding Mgmt-intf
 ip address 10.255.0.52 255.255.0.0
 duplex full
 speed auto
 media-type rj45
interface GigabitEthernet0/1
 description to iosvl2-1
 no ip address
 ip ospf cost 1
 duplex full
 speed auto
 media-type rj45
interface GigabitEthernet0/1.10
 encapsulation dot1Q 10
 ip address 192.168.10.254 255.255.255.0
 no cdp enable
interface GigabitEthernet0/1.20
 encapsulation dot1Q 20
 ip address 192.168.20.254 255.255.255.0
 no cdp enable
router ospf 1
 passive-interface Loopback0
 network 10.0.0.0 0.0.255.255 area 0
 network 192.168.0.1 0.0.0.0 area 0
router bgp 1
 bgp router-id 192.168.0.1
 bgp log-neighbor-changes
 neighbor 192.168.0.2 remote-as 1
 neighbor 192.168.0.2 description iBGP peer iosv-2
 neighbor 192.168.0.2 update-source Loopback0
 neighbor 192.168.0.3 remote-as 1
 neighbor 192.168.0.3 description iBGP peer iosv-3
 neighbor 192.168.0.3 update-source Loopback0
 address-family ipv4
  network 192.168.0.1 mask 255.255.255.255
  neighbor 192.168.0.2 activate
  neighbor 192.168.0.3 activate
 exit-address-family
ip forward-protocol nd
no ip http server
no ip http secure-server
ip ssh server algorithm authentication password
ipv6 ioam timestamp
control-plane
banner exec `
* IOSv is strictly limited to use for evaluation, demonstration and IOS  *
* education. IOSv is provided as-is and is not supported by Cisco's      *
* Technical Advisory Center. Any use or disclosure, in whole or in part, *
* of the IOSv Software or Documentation to any third party for any       *
* purposes is expressly prohibited except as otherwise authorized by     *
* Cisco in writing.                                                      *
banner incoming `
banner login `
line con 0
 password cisco
line aux 0
line vty 0 4
 exec-timeout 720 0
 password cisco
 login local
 transport input telnet ssh
no scheduler allocate
end
</entry>
            <entry key="AutoNetkit.ASN" type="Integer">1</entry>
        </extensions>
        <interface name="GigabitEthernet0/1" id="0" ipv4="10.0.0.1" netPrefixLenV4="16"/>
    </node>
    <node location="341,295" type="SIMPLE" subtype="IOSv" name="iosv-2" ipv4="192.168.0.2">
        <extensions>
! Last configuration change at 03:21:17 UTC Wed Oct 30 2019
version 15.7
hostname iosv-2
boot-start-marker
boot-end-marker
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
no aaa new-model
no mmi pvc
no ip domain lookup
ip cef
ipv6 cef
username cisco privilege 15 secret 5 $1$8L3p$7R8TiDN04oqCmvqfC5fQg.
redundancy
no cdp run
interface Loopback0
 ip address 192.168.0.2 255.255.255.255
 ip address 10.255.0.53 255.255.0.0
 duplex full
 speed auto
 media-type rj45
 ip address 192.168.10.100 255.255.255.0
 ip ospf cost 1
 duplex full
 speed auto
 media-type rj45
router ospf 1
 network 192.168.0.2 0.0.0.0 area 0
router bgp 1
 bgp router-id 192.168.0.2
 neighbor 192.168.0.1 remote-as 1
 neighbor 192.168.0.1 description iBGP peer iosv-1
 neighbor 192.168.0.1 update-source Loopback0
 address-family ipv4
  network 192.168.0.2 mask 255.255.255.255
  neighbor 192.168.0.1 activate
 exit-address-family
ip default-gateway 192.168.10.254
no ip http server
ipv6 ioam timestamp
control-plane
banner exec `
banner incoming `
banner login `
line con 0
 password cisco
line aux 0
line vty 0 4
 exec-timeout 720 0
 password cisco
 login local
end
</entry>
        </extensions>
        <interface name="GigabitEthernet0/1" id="0" ipv4="10.0.0.2" netPrefixLenV4="16"/>
    </node>
    <node location="792,295" type="SIMPLE" subtype="IOSv" name="iosv-3" ipv4="192.168.0.3">
        <extensions>
! Last configuration change at 03:21:28 UTC Wed Oct 30 2019 by cisco
version 15.7
hostname iosv-3
boot-start-marker
boot-end-marker
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
no aaa new-model
no mmi pvc
no ip domain lookup
ip cef
ipv6 cef
username cisco privilege 15 secret 5 $1$ZfqT$ddsaKnKcxomWzc28tb4Vs0
redundancy
no cdp run
interface Loopback0
 ip address 192.168.0.3 255.255.255.255
 ip address 10.255.0.54 255.255.0.0
 duplex full
 speed auto
 media-type rj45
 ip address 192.168.20.100 255.255.255.0
 ip ospf cost 1
 duplex full
 speed auto
 media-type rj45
router ospf 1
 network 192.168.0.3 0.0.0.0 area 0
router bgp 1
 bgp router-id 192.168.0.3
 address-family ipv4
  network 192.168.0.3 mask 255.255.255.255
 exit-address-family
ip default-gateway 192.168.20.254
no ip http server
ipv6 ioam timestamp
control-plane
banner exec `
banner incoming `
banner login `
line con 0
 password cisco
line aux 0
line vty 0 4
 exec-timeout 720 0
 password cisco
 login local
end
</entry>
        </extensions>
        <interface name="GigabitEthernet0/1" id="0" ipv4="10.0.0.3" netPrefixLenV4="16"/>
    </node>
    <node location="574,295" type="SIMPLE" subtype="IOSvL2" name="iosvl2-1">
        <extensions>
! Last configuration change at 03:24:07 UTC Wed Oct 30 2019 by cisco
version 15.2
service compress-config
hostname iosvl2-1
boot-start-marker
boot-end-marker
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
username cisco privilege 15 secret 5 $1$BABH$V0reLxw5mzQyhoZnxjGxK1
no aaa new-model
vtp domain virl.lab
vtp mode transparent
no ip domain-lookup
ip cef
no ipv6 cef
spanning-tree mode pvst
vlan 2
 name ank_vlan2
vlan 10
 name net10
vlan 20
 name net20
no cdp run
interface Loopback0
 no ip address
 description OOB management
 no switchport
 ip address 10.255.0.55 255.255.0.0
 negotiation auto
 description to iosv-1
 switchport access vlan 2
 switchport trunk allowed vlan 10,20
 switchport mode trunk
 negotiation auto
interface GigabitEthernet0/2
 description to iosv-2
 switchport access vlan 10
 switchport mode access
 negotiation auto
interface GigabitEthernet0/3
 description to iosv-3
 switchport access vlan 20
 negotiation auto
no ip http server
ip ssh server algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip ssh client algorithm encryption aes128-ctr aes192-ctr aes256-ctr
control-plane
banner exec `
banner incoming `
banner login `
line con 0
 password cisco
line aux 0
line vty 0 4
 exec-timeout 720 0
 password cisco
 login local
end
</entry>
        </extensions>
        <interface name="GigabitEthernet0/1" id="0"/>
        <interface name="GigabitEthernet0/2" id="1"/>
        <interface name="GigabitEthernet0/3" id="2"/>
    </node>
    <connection src="/virl:topology/virl:node[4]/virl:interface[2]" dst="/virl:topology/virl:node[2]/virl:interface[1]"/>
    <connection src="/virl:topology/virl:node[4]/virl:interface[3]" dst="/virl:topology/virl:node[3]/virl:interface[1]"/>
    <connection src="/virl:topology/virl:node[1]/virl:interface[1]" dst="/virl:topology/virl:node[4]/virl:interface[1]"/>
</topology>
at first glance, it looks like your are not announcing any of the local networks in OSPF. Add the lines in bold to your configs:
iosv-1
router ospf 1
network 192.168.10.0 0.0.0.255 area 0
network 192.168.20.0 0.0.0.255 area 0
iosv-2
router ospf 1
iosv-3
router ospf 1
5 Replies 5
iosv-1
router ospf 1
iosv-2
router ospf 1
iosv-3
router ospf 1
Hi George
Finally, I have time to test your solution and it's working.
Based on your quick response I suppose it's something trivial which left me confused because this lab is part of chapter 2 of the book I'm studying from and it doesn't mention anything about the OSPF. The OSPF is part of chapter 11 which is a long way to go. Now I have to search for the command of how to announce the local networks in the OSPF.
Many thanks for your solution.
Richard Burts
There are some things about the environment here that are not clear to me. Such as what kind of device are iosv-2 and iosv-3. Since they have multiple interfaces with IP addresses and since they are configured to run OSPF and BGP I assume that they are some type of layer 3 router. And in that case the major issue is that both devices are configured with ip default-gateway and do not have any ip route statements. The issue is that ip default-gateway is only used when the device is operating as a layer 2 host and is not used when the device is operating as a layer 3 device. You need routing logic for those networks - either configure static routes or include 192.168.10.0 and 192.168.20.0 in your OSPF.
Rick
Rick
Hi Richard
You're right the iosv-2 and iosv-3 are indeed routers. Those host devices suppose to be PCs, but it's much easier and faster to set the simulation with routers instead.
I have been able to ping through with George's solution.
Thanks for your contribution.
Thanks for the explanation and the additional information. If you intended these devices to be hosts in the network (rather than routers in the network) then you could achieve that by using the command "no ip routing" in their configuration. And if you had done that then the ip default-gateway command would have worked - and I believe you would have the connectivity you were trying to achieve.
But if they were configured as routers then the suggestion to include the network command in the OSPF config was the correct solution.
Rick
Rick
