IOS features
Zikosenpay
Community Member
I have s72033-advipservicesk9_wan-mz.122-33.SXH8b.bin image, and I want to know if this image support VSS with two superviser engine 720-10G  on both catalyst6509 ?
Thanks in advance
Sandeep Choudhary
Hi Zi,
As per this tools this IOS supported the VSS.
just check again on this tool.
http://tools.cisco.com/ITDIT/CFN/Dispatch
Please rate if it helps.
Hi Sandeep,
the link is not working
I know that it supports VSS, but in my case i have two 6509 with two 720-10G superviser engines on both
I want to know if this IOS supports VSS with all of them, quadro vss
HI Zi,
go tothis webpage and then click search by software and the put your image name :s72033-advipservicesk9_wan-mz.122-33.SXH8b
it will show all the feauture which is supported by this image.
Leo Laohoo
I believe dual supervisor card per chassis is supported starting from SXI4.
