IOS IP Base and NAT
t511820
Can i run NAT i IOS IP BASE?
regards
Nguyen Thanh Hieu
Jon Marshall
IP Base on what device. If you are referring to the 3550/3650/3750 switches then no you cannot run NAT. In fact the only swith that can run NAT, regardless of IOS version, is 6500.
Jon
