IOS NAT over multiple outbound interfaces
axium
Our 3845 have 2 public FEthernet interfaces with /24 addresses and a public Serial P2P interface with default outbound route. Can we make internal 10.0.0.0/24 hosts NATed over those 2 public netblocks /24 instead of Serial global PAT and able to route those NATed public IP through this Serial interface and reach internet?
Dave
Dave,
I hope I understood your requirement correctly. You have two public class C networks and you want to NAT your internal hosts to use an address from this range.
You sure can do it provided, your ISP connected via Serial Interface knows these two networks can be reached via their serial connection to you.
If you have a different requirement then could you clarify that for us.
HTH,
Sundar
Hi Sundar,
Thanks for the reply, So is this following config. works or do I have to use vrf?
Dave
interface vlan10
description $inside private address$
ip address 10.10.10.0 255.255.255.0
ip nat inside
interface Vlan57
description $outside public address$
ip address 64.57.xx.1 255.255.255.0
ip nat outside
interface Vlan65
ip address 64.65.xx.1 255.255.255.0
ip nat outside
interface Serial2/0
description $P2P to ISP$
ip address 46.xx.xx.54 255.255.255.252
ip nat outside
ip route 0.0.0.0 0.0.0.0 46.xx.xx.53
ip nat pool NET65 64.65.xx.4 64.65.xx.14 netmask 255.255.255.0
ip nat pool NET57 64.57.xx.4 64.57.xx.14 netmask 255.255.255.0
ip nat inside source list 4 pool NET65 overload
ip nat inside source list 4 pool NET57 overload
access-list 4 permit 10.10.10.0 0.0.0.255
Dave,
The configuration looks good. Are these two networks, 64.57.xx.0/24 & 64.65.xx.0/24, assigned to you by the ISP connected via serial2/0 and if it is then it should work fine.
You don't even need to use NAT overload option as the config only shows you have 254 internal hosts or less. NAT overload makes it PAT, which I believe you don't want.
HTH,
Sundar
